#1 Posted : 12 May 2020 03:31:43(UTC)
For many years, the only way to make the content of a RemoteSign screen change, was from another copy of RemoteSign, the DB schedule program, or dedicated software, and from last year, also from RemoteSign Sequencer.
The good news is that you can now get data into RemoteSign Sequencer using a helper program called RSRelay, and this can be done from any program that can launch an external program with a parameter, and that includes TrainController from RailRoad & Co.
Here is an overview: RSRelay
and here is information on how to use it from TrainController:
https://remotesign.mixmox.com/p/calling-rsrelay-from-traincontroller.html
If you know of other layout control programs that can launch an external program, I would be happy to also document how it is done. I suspect other such as JMRI and RocRail can probably also do it too.
Of course actual dedicated support for RemoteSign will make it much easier than preparing scripts, so feel free to ask your software vendor to add RemoteSign support to your software. To that end there is a link you can provide to them also.
Offline Danlake
#2 Posted : 12 May 2020 11:24:06(UTC)
Danlake
That's very interesting Dale,
I am presently using text variables to use my own little time schedule in Traincontroller.
So in your program how do you update the time table with train having arrived and departed at a station? Assume it would be based on actual activation of contact tracks?
Just curious how it works? Because within Train controller it was somewhat complicated to create the required criteria when to update the text string with present time (e.g. only when this train on that schedule arrives at that particular contact).
Thanks!
Best Regards
Lasse
#3 Posted : 12 May 2020 15:15:42(UTC)
It simply triggers a script in Sequencer. The script can be a single line or something complex. So one script can clear a line and other scripts place content onto teh line.
Within RemoteSign Sequencer, one can use time macros, allowing you to 'soft code' the time from now to 99 minutes in the future.
So say you have a station with 4 platforms, you would create 4 scripts to clear each track (one line of code each). (The sample file is in fact already set up with 5 tracks, so this is already done.)
If you have 5 possible destinations, you could create a script for each track that cycled through the 5 destinations on each subsequent call.
I don't use TC myself so I am not familiar with it much at all. I would like to know if TC can pass those text variable to the external program... if so, I can allow things like train name, and destination to be dynamically passed in.
Direct native support for RemoteSign would be preferable of course, but that is for users to lobby RailRoad & Co to do!
#4 Posted : 13 May 2020 15:38:57(UTC)
if you can combine your text variables when you call the execute function, then you could build up a script name using train, platform, destination, etc.
Eg ICE12345^01^Hamburg-Altona
Another possible solution would be for me to extend Sequencer that allows you to store text variables.
You could then make say 3 calls, one passing the train name, one teh platform, and the third the destination.
A 4th call tell it to put them all together and display it....
Petitioning Freiwald software to just add direct support would be much better though.
#5 Posted : 22 May 2020 16:26:26(UTC)
If TrainController is able to write text files, then this brand new feature of RemoteSign Sequencer will be able to take advantage of that data.
https://remotesign.mixmox.com/p/data-source.html
This page was generated in 0.301 seconds.
