Offline Johnvr
#1 Posted : 27 April 2020 12:57:43(UTC)
Johnvr
Hi all
I discovered quite by accident a simple little trick to make your digital conversion easier.
The trick is :
Let the magnet be the last item to insert into the motor once your digital conversion has been done !
I have sometimes struggled with getting the armature aligned with the gears.
And then I have wanted to turn the wheels to ensure that all the gearing works well.
In the past, I would assemble the magnet into the motor and then that would make the conversion a little more difficult than it needs to be.
In future, the magnet goes in last !
RegardsBigGrin
#2 Posted : 27 April 2020 16:06:32(UTC)
John,
unfortunately you haven't convinced me why one should put the little magnet last. looking at your brush plate its not 100% aligned and maybe the altered brush plate has something to do with it, when you look at the top end right corner you can see the plate is not within the notch
#3 Posted : 27 April 2020 17:43:02(UTC)
Hi John VR
My past experience (I am no specialist having converted 25 or so locos including steamers, diesels and electrics) is that:
- the inductor (assembly with the magnet) placing is critical and uneasy
- often it is easier to place simultaneously the inductor and the rotor because access could be limited by adjacent wheels
- the correct position of the inductor vis à vis the rotor needs to be verified before wiring: check free operation without brushes
- a quick test with only the 4 main wires (red, brown, green and blue: rail inputs and motor outputs) to check the correct functioning of the motor and the decoder. This before a very clean and complete wiring.
This page was generated in 0.258 seconds.
