Offline ktsolias
#1 Posted : 27 March 2020 12:16:26(UTC)
ktsolias
Hi to all
The Märklin 3462 is a GM EMD F7 loco of the "ALASKA RAILROAD"
Produced in one time series in 1993 for the occasion of "70 years of the Alaska Railroad".
The loco has three parts: 2A units with engineer's cabs (Road No 1500 and 1502) and one B unit without engineer's cab (Road No 1503)
The units are permanently coupled.
There are 2 DCM motors (1 in each A unit) an electronic reversing unit in 1500.
4 axles are powered and there are 8 traction tires.
There is one pick-up shoe (7164) in the front bogie of the B unit.
The total length is 52 cm.
This conversion applies and in other 3 Unit F7 produced by Märklin the same period e.g.:3481, 3349, 3362
The project is: Digital conversion with sound.
The plan is to convert the loco with two 60941 5 pole motors and to drive them with a single 60946 Märklin Decoder.
LED lights.
The opening of the units is straightforward: just one screw for each unit underneath.
Put marks for the end A units who is front and who rear
Inside we can see the motors the reversing unit etc.
The A unit with the motor and the E-reversing unit
The front light
The B unit.
There is a contact PCB there like a main distribution board.
The other A unit with only the motor
Desolder everything
Check and clean all the parts and especially the motor bogies
The bogies with the new motors
The motor in place
I decided to put the decoder and the speaker into the B unit.
Next to the distribution PCB.
The two motors connected with the decoder in parallel.
The measurements of the consumption of the two motors with the CS3 reveals that the decoder output is enough for the two motors.
I put a 5mm WW LED soldered on the PCB with a 1kΩ resistor on AUX 1 for some light in the engine room B.
You can see the soldering of the various wires. Märklin color code
The B unit with the decoder speaker etc
For the front and rear lights I used 5mm WW LED's plunged in the original socket, with a dropping resistor 1kΩ in series on the negative for each LED.
Of course there are many lighting possibilities as there are 3 AUX still available plus plenty of space in the loco complex.
The final result:
The front 1500
The rear 1502
The middle 1503
And finally a short video with the Loco in motion
An interesting easy conversion who gives new life and dimension to these beautiful units.
And at the end something very sad:
This post is DEDICATED in the MEMORY of the OWNER of the loco who unfortunately has Pass Away on 24/3/2020 from the Covid-19......
He never put his hands on the converted loco.........
Best regard to all of you and good health to you and your beloved persons.
Stay in and play with Trains.
IS VERY SAFE
Costas
thanks 14 users liked this useful post by ktsolias
#2 Posted : 27 March 2020 12:35:05(UTC)
Hi Costas
Beautiful loco and very sad ending.
Thank you for this report. I have a blue Santa Fe triple unit (3662) that could be a candidate for conversion exactly like yours.
Offline bph
#3 Posted : 27 March 2020 19:34:32(UTC)
Nice locomotive and a nice conversion job, but unfortunately with a sad ending.
Thanks for sharing.
#4 Posted : 27 March 2020 23:52:43(UTC)
Outstanding work, as always Kostas!
When I converted mine, I added an orange LED on the roof of each cab (you'll need a small hole to be drilled) and programmed the function output to simulate a rotary beacon light.
Really easy to do, not expensive either Wink
Of course I was using an ESU Loksound at the time.
I don't know whether the Märklin decoder offers the same feature, but honestly it was definitely a crowd pleaser !
Just a thought
Sorry to read the sad end of the story, let's stick to our trains and other homebound hobbies.
#5 Posted : 28 March 2020 05:55:19(UTC)
I have done exactly the same conversion to 3462 and 3662 F7 models,they are working perfect for a lot of years,great result,congratulations.ThumpUp
#6 Posted : 28 March 2020 08:35:34(UTC)
I also have a 3662 that I wish to convert. My plan is to use a Loksound decoder as it is possible to make it sould like multiple power units starting in sequence, which is ideal for an MU like this. I know people have done two power units, I don't know if three have been tried.
#7 Posted : 28 March 2020 09:35:39(UTC)
I have never tried something like that,I am rumning these units with a lot of wagons,more than 50 sometimes,the weight is high.Three motors and so much weight i think it is risky to blow up the decoder,just my opinion.
#8 Posted : 28 March 2020 10:15:39(UTC)
Hi Alan
No problem of course with the "A" units, but you'll need to change the chassis of the "B" unit if you want three motors.
At one point one could buy the chassis and teh motors separately, but I have not verified that alternative.
You could always buy a cheap second hand F7 and refit if with your 3662 B unit body.
You will have to saw off a little part of the chassis , the "B" units are shorter.
To support your idea; I have a 4 units Union Pacific F7 latch up, with one sound decoder per unit, and indeed starting the motors in sequence is merely a matter of assigning a different function key to starting the sound of the respective decoders.
It is spectacular, with a very realistic "stereo" effect as the loco moves around the layout.
BUt of course, it's expensive too...
Stay safe
Jacques
#9 Posted : 28 March 2020 12:01:26(UTC)
I used to own one of these, converted i but sold it later on., I would like to make you aware your bogies front & rear don't seem to line up especially both front axles showing less wheel than the back one.
I added ball bearings and the same as Jacques added a rotary light on top of the cab, I also separated the front light with 2 function output and the same goes for the road number.
excellent conversion
Offline ktsolias
#10 Posted : 28 March 2020 12:22:44(UTC)
ktsolias
Thank you John
You are correct there was a problem with the bogie frames because the coupler in the one side was wrong screwed on the bogie. I noticed that and corrected it later. I had done the videos and photos before....
Of course there are many possibilities to add functions (3 AUX available) or do many things with function mapping. Plus to much space to put in custom electronics.
But this was a conversion for somebody else so I had to be in limits mainly on the cost side.
Kostas
#11 Posted : 29 March 2020 01:14:47(UTC)
Hi Alan
Jacques
Ah, no confusion reigns ... Blink
I am talking about motor sounds, not actual motors on the bogies. The Loksound decoders have a facility whereby it is possible to have multiple motor sounds, ideal for locos which had multiple engines that would be started in sequence. I would have thought that an ABA set would have the motors start in sequence rather than all simultaneously. I am just not sure how this will sound coming out of one speaker.
In retrospect I believe I have the model number wrong, mine is the GM prototype loco (the first ABA unit Marklin made) which is I think 3649.
Offline HerrDoktorBD
#12 Posted : 08 August 2020 19:36:19(UTC)
HerrDoktorBD
I'm about to embark in this conversion, waiting for decoder and motors. In the meantime, the set came with a couple of yellow foam pieces between the units (see pic). I got the foam out but there's residue left over. Not wanting to damage the paint I decided to consult this fine forum for advice. What solvent would be best to get the residue off the bodies? Alcohol, acetone, goo-gone?
Thanks in advance for your help.
Regards, Tony
#13 Posted : 09 August 2020 00:51:40(UTC)
Regards, Tony
I would use warm soapy water after removing the bodies from the chassis. Use an old toothbrush to scrub the debris off.
If you use any of the items you mention then it is likely you will damage the paint.
#14 Posted : 09 August 2020 01:11:34(UTC)
HerrDoktorBD
Aha! The old warm water and toothbrush ploy, eh?
Thank you, Alan. That worked.
#15 Posted : 18 August 2020 15:07:20(UTC)
HerrDoktorBD
Digital conversion successful.IMG_7021.jpeg IMG_7026.mov (10,979kb) downloaded 29 time(s).
thanks 2 users liked this useful post by HerrDoktorBD
Online Alsterstreek
#16 Posted : 18 August 2020 16:39:52(UTC)
Is the decoder resting on the metal chassis? If so, that would be quite risky...
#17 Posted : 18 August 2020 16:50:41(UTC)
HerrDoktorBD
The decoder motherboard is in its plastic holder.
thanks 1 user liked this useful post by HerrDoktorBD
Offline europromo
#18 Posted : 16 September 2021 21:27:10(UTC)
europromo
Just bought the set with the 10 freight cars. Now I’m thinking should I do convert to digital or have a separate analog circuit on my layout? That way I could run my TEE w/o conversion.
This page was generated in 0.807 seconds.
