Offline iainp
#1 Posted : 06 March 2020 10:39:09(UTC)
iainp
I have just added a Memory to my set of digital controllers. I have powered up the Memory and all the lights come on OK. I have reset it by completely deleting all the old stored routes. However, when plugged in to my Keyboard the Keyboard ceases to work. Any ideas as to what might be the problem or is my Memory dud?
Offline amartinezv
#2 Posted : 06 March 2020 16:41:27(UTC)
amartinezv
The memory must be connected to the left side of the 6021 (or 6020 or central you have), usually connected to the last keyboard (also connected by the left side), ie would be something like:
Memory-->Keyboard-->central unit
The memory on the front has 4 switches, with the switches 1 and 2 you must put its address (1 by default), check these things, check that the keyboard and memory do not have any bent pin.
You will tell us
Greetings
Antonio Martínez
www.raildigital.es/davidruso
thanks 1 user liked this useful post by amartinezv
#3 Posted : 06 March 2020 21:08:44(UTC)
Related:
Suggest poping the top of the unit and check the battery has not leaked
#4 Posted : 07 March 2020 02:22:53(UTC)
Related:
How to do this :
https://www.marklin-user...ra-controller#post554872
also :
Memory tutorial.pdf (60kb) downloaded 28 time(s).
and I trust you have :
Memory 6043 Manual copy.docx (3,659kb) downloaded 20 time(s).
Smile
Edited by user 07 March 2020 07:33:12(UTC)  | Reason: Not specified
#5 Posted : 08 March 2020 02:48:37(UTC)
Originally Posted by: amartinezv Go to Quoted Post
... check that the keyboard and memory do not have any bent pin...
ThumpUp
This page was generated in 0.458 seconds.
