Offline pclancy
#1 Posted : 28 January 2020 13:26:30(UTC)
pclancy
Hi folks:
Ok, I have set up a simple oval using my white marklin transformer. It works great. All my 30 year old locos just purr.
Now I have found a second transformer in the attic--a blue 37547. Hmmm.
Can I run a more elaborate layout, with two locos running at the same time using two transformers? I am thinking about one oval with two turns outs to allow a separate block.
I assume I need to make the transformers power different parts of the more elaborate oval separately, so as to not have two transformers powering the same block of track.
Can one transformer power two locos at the same time? If they are both on the same block, will one necessarily catch up with the other?
I have absolutely now idea how one does this. I am lost as to what is needed in terms of parts.
I am using both C and M track.
Thanks very much,
#2 Posted : 28 January 2020 14:10:07(UTC)
You can use it. As long as you dont use any modern lcoos with digital decoders in them.
Yes, you will have to connect the trafos to 2 DIFFERENT sections. With M-track you isolate the sections by inserting a piece of paper (or plastic) between the center-stud contact tongues. (Powered by the red wires)
The brown wires of the two trafos must be connected to each other (and to the tracks, as always)
Think of the brown as "chassis" o "zero" or "ground". -Which must be common for all parts.
The red wire from the trafos are the "live" or "phase" wire, which you must run to the specific sections you want to control.
(The yellow wire is also "live", but is always 16Vac. -For lights and electric accessories)
For isolating the center studs on C-tracks, you will need some red plastic-shoes that fit over the contacts, where you assemble the tracks.
That trafo is weak. Around 10VA if I remember correct. -So really only for one loco at a time. (Although you wont break anything if you happen to run 2 locos at some point)
If you can get hold of some older Märklin catalogues, you can see diagrams of how to do this, in the track-sections there...
Extra: When you want to use more than 1 trafo, you will need to make sure that they are in the same "phase". When you connect the 2 brown wires, NO SPARK must appear wbetween the 2 red wires.
If a spark appears (dont worry, it wont harm you, and you wont destroy anything) then the plug in the socket in the wall must be turned 180º. Only do this for ONE of the trafos.
Best tested with a bulp between the 2 brown wired before connecting them to the common ground. (If there is NO light in the bulp, the phase is correct.)
I am sorry if this last comment is not very clear. You can still play with your trains although you dont do this, it´s just not... right.
Offline kgsjoqvist
#3 Posted : 28 January 2020 22:00:30(UTC)
kgsjoqvist
Running two locos at the same time from one trafo is possible, but not practical. Depending on the loco they may or may not have the same speed. The direction of travel may also be different. If you turn the knob to change it, both locos Will change direction.
The traditional way to handle two locos from one trafo is to use signal. When one train is stoppet by a red signal, the other can be controlled individually.
#4 Posted : 05 February 2020 09:00:27(UTC)
Do not connect the 2 transformers from a different socket outlet.
This page was generated in 0.497 seconds.
