Offline rhfil
#1 Posted : 10 January 2020 16:40:03(UTC)
rhfil
I have my first engine with a smoke generator and have some questions. Is it necessary to put in just the amount of liquid that you will burn off? What happens to the liquid that is not burned off?
Offline dickinsonj
#2 Posted : 11 January 2020 00:49:20(UTC)
You can put in more if you will be using it again fairly soon - maybe within a couple of months. The important bit is to not put in too much because that leads to all manner of problems when it overflows and gets all over the place. ThumbDown
In any reasonable amount of time it just sits there, unless you handle the loco and turn it over, in which case it will run out on the outside and make another and different mess. ThumbDown
And you should not power the smoke generator when it is dry, which at least in the past would toast them for sure. BigGrin
Offline Elsleuth1
#3 Posted : 11 January 2020 00:53:06(UTC)
Elsleuth1
7 or eight drops works well for me. It only takes a few minutes of running to exhaust your supply from my experience
thanks 1 user liked this useful post by Elsleuth1
Offline rhfil
#4 Posted : 11 January 2020 02:20:52(UTC)
rhfil
Thanks for the replies.
Custom smoke generator for digital use (Digital)
by einotuominen 17/02/2024 11:44:17(UTC)
Smoke generator (H0-scale)
by Keim 01/03/2023 01:58:22(UTC)
Smoke Generator for Marklin 5441 Set (Big scale)
by JTaylo93 22/01/2023 16:57:27(UTC)
Sk800 smoke generator (General MRR)
by Keim 29/07/2022 23:05:41(UTC)
Smoke generator and LokSound XL (Big scale)
by ktsolias 25/08/2021 11:33:31(UTC)
Smoke Generators For Maxi Locomotives?? (Big scale)
by ErikNewland98 20/11/2020 07:16:17(UTC)
Roco BR86 Steam loco smoke generator (H0-scale)
by seanshintaro 16/03/2020 07:53:35(UTC)
Adding Smoke Generator to Starter set Loco? (H0-scale)
by SBB_CFF_FFS 03/01/2020 02:32:44(UTC)
72270 smoke generator (H0-scale)
by Seaquake 14/11/2018 18:41:47(UTC)
Smoke generator fluids - scented no oil? (General MRR)
by Minok 14/04/2018 23:23:05(UTC)
Smoke generator for 3092 Lok-Question (H0-scale)
by analogmike 05/12/2017 03:05:52(UTC)
Smoke generator liquids (General MRR)
by ocram63_uk 01/10/2017 14:20:00(UTC)
Seuthe Smoke generator quirky (H0-scale)
by Zeitgaiss 21/09/2017 15:04:35(UTC)
Steam #3005 ...Smoke Generator? (H0-scale)
by Zeitgaiss 14/09/2017 16:04:25(UTC)
39551 G 5/5 Smoke Generator Installation (H0-scale)
by CanadianKid 29/04/2017 07:59:19(UTC)
Märklin 55441 smoke generator (Big scale)
by airsoftrc 13/04/2017 23:48:47(UTC)
Glowing Smoke Generator in BR 95 - 39095 (H0-scale)
by Armando 07/01/2017 23:38:09(UTC)
Problem with Seuthe 10 Smoke Generator Installation (Digital)
by AmalfiCoast 25/12/2016 19:22:06(UTC)
7226 Smoke Generator... is it on? (H0-scale)
by Minok 16/12/2016 22:21:11(UTC)
New technology smoke generator (Digital)
by river6109 01/04/2016 01:21:43(UTC)
Smoke generator always on (General MRR)
by waorb 18/03/2015 15:41:43(UTC)
Smoke Generator with 60965 ? (H0-scale)
by GvanWyk 26/06/2014 21:55:10(UTC)
BR24 from startset 29240 - Smoke generator contact function in MS2? (H0-scale)
by marc 04/03/2014 22:26:42(UTC)
installininstalling smoke generator to Marklin BR 80 from start set 55035 (Digital)
by tsigkas 19/12/2012 16:10:09(UTC)
How to install the smoke generator in BR50.40 (H0-scale)
by shannon 27/03/2012 04:09:38(UTC)
Introduction of newbie&Smoke generators overloading 37024 (Digital)
by 65kombi 03/01/2012 04:39:35(UTC)
Advice on smoke generator and ESU lokpilotv4 (Digital)
by French_Fabrice 11/12/2011 09:30:42(UTC)
Which smoke generator (H0-scale)
by gachar001 01/08/2011 03:40:05(UTC)
Smoke Generator issue with a 3092 Engine not working (H0-scale)
by jbn1jbn 09/01/2011 00:37:42(UTC)
Smoke Generator issue with a 3092 Engine (Model railroad wiring)
by jbn1jbn 09/01/2011 00:36:07(UTC)
Smoke Generator/Rauchsatz (H0-scale)
by wolfk88 04/12/2010 20:06:25(UTC)
7226 Smoke Generator Problem (Digital)
by JH 30/11/2010 17:44:02(UTC)
Smoke generator question for M* 26562 (H0-scale)
by gachar001 23/09/2010 18:13:39(UTC)
Installing smoke generators on Marklin trains,should a rookie attempt it? (H0-scale)
by I_love_Marklin_37538 15/09/2010 09:22:22(UTC)
Installing smoke generator in BR10.0 (H0-scale)
by Armando 05/11/2009 22:54:59(UTC)
cleaning a smoke generator in BR 50 (H0-scale)
by kimballthurlow 03/03/2009 15:12:32(UTC)
BR23 (36240) Smoke Generator (H0-scale)
by jmgepb 08/01/2009 16:38:44(UTC)
Which smoke generator is right ? (Digital)
by wurttemberg 23/12/2008 23:42:56(UTC)
Smoke Generator question 72270 vs. 7226 (H0-scale)
by MARKLIN LOVER 06/12/2008 01:16:05(UTC)
smoke generator, advice needed (H0-scale)
by Seetal 12/10/2008 22:47:32(UTC)
BR50 smoke generator issue (H0-scale)
by gachar001 10/06/2008 17:56:58(UTC)
Equivalant smoke generator (H0-scale)
by Legless 24/05/2008 14:38:08(UTC)
Smoke Generators ON and OFF (H0-scale)
by DamonKelly 15/09/2007 17:53:18(UTC)
Question on smoke generator (H0-scale)
by efel 09/10/2006 17:00:29(UTC)
Smoke generator for a 3048 steamer (H0-scale)
by dbmike 08/10/2006 05:18:43(UTC)
72270 Smoke generator kit (Digital)
by kiwi 05/07/2006 12:28:47(UTC)
Digitalizing and smoke generator (Digital)
by al_pignolo 26/03/2006 21:20:30(UTC)
Märklin smoke generator (72270) (General MRR)
by dakje_Rook 11/01/2006 21:20:24(UTC)
Smoke Generators. (General MRR)
by franciscohg 22/10/2005 21:36:35(UTC)
Some smoke generator questions, for you smokers (H0-scale)
by Sam 23/03/2005 06:23:32(UTC)
This page was generated in 0.543 seconds.
