Offline pclancy
#1 Posted : 04 January 2020 17:28:21(UTC)
pclancy
Dear Forum members:
As a young boy, I grew up with Marklin. Now, I am retired and am thinking about setting up a layout.
I have old Marklin M track, blue transformers and locomotives that date to the 60s. I have a ton (50-100) pieces of old M track, but I assume it is generally in poor condition--it's been stored in boxes in heated and unheated garages since the 60s. Never wet, but old and dusty and cold. Some of it is bent, I assume, and I can dimly remember how some pieces didn't work well when I was a kid!
I am clueless about how Marklin works these days--except that it has gone digital. My locos are analog. I have plenty of rolling stock.
Where do I start? I want to build a medium sized layout, with a loop inside a loop. Maybe a bridge or tunnel. That's it.
I want to buy used.
Where can I access a layout diagram? Does it list all the pieces needed? Should I ditch the M and go for C? Who can digitize the locos?
What's the best way to proceed?
Thanks for your advice!
thanks 1 user liked this useful post by pclancy
#2 Posted : 04 January 2020 19:50:24(UTC)
About old blue metal transformers:
https://www.marklin-user...--white-transformer-32Va
Scanned copies of M track plan books:
http://www.lctm.info/Sec...lioteca/Libros/index.php
No need to go digital, but if you desire to convert vintage analog locos to digital (which is possible), you need modern generation controls, too.
Offline hvc
#3 Posted : 05 January 2020 00:14:51(UTC)
hvc
Hi Peter,
Welcome to the forum!
Ak (above) is right - you can just stick with M track and analogue if you want - just buy a new transformer/controller for safety reasons.
C track isn't necessary, but it is a leap forward in terms of reliability and ease of set up - but plenty of forum members here are still running on M track (and lots on K track as well, of course).
I was in the same position as you about 15 years ago - lots of M track and analogue. I decided to start by buying a second-hand start-set, which included a simple C-track layout, a digital controller (called a "Mobile station") - something like this:
https://www.modellbahnshop-lippe.com/Starters+%26+Sets/Start%2DSets+digital/M%C3%A4rklin%2D29074/gb/modell_256297.html
and I also bought a couple of C to M track adapters:
https://www.modellbahnshop-lippe.com/Railtracks/Standard+Railtracks/M%C3%A4rklin%2D24951/gb/modell_4431.html
so that I could still use M track while I gradually bought more C track.
I still have analogue locomotives as well as digital - like many here, I can run my layout in either digital or analogue by just switching to a different controller.
Hope this helps!
-Herman
- Herman
thanks 2 users liked this useful post by hvc
#4 Posted : 05 January 2020 20:01:22(UTC)
Hi- your track may be usable with some patience. Assuming no rust, a good wash in the sun on a warm day with soap and water and then a thorough drying will do 80+% of the job. Then a commercial track eraser over the rails, and then some wahl clipper oil gently applied with a rag or paper towel to the railheads to keep it clean.
Then when assembling check the joints and with a pair of hobby/small needlenose pliers you can straighten any rails where the may have been bent at the joints. Enjoy!
It sounds like a lot of work, but when doing a huge batch of track all at once it goes quickly
Offline pclancy
#5 Posted : 05 January 2020 20:13:36(UTC)
pclancy
Great advice everyone! Thank you so much. Am I correct in assuming that I can run both C and M track together using a mobile station and digitized locos?
#6 Posted : 05 January 2020 21:39:43(UTC)
Yes you can. Marklin make straight adapter tracks to connect C and M track together.
Early MARKLIN 1 Gauge Steam Engine I think? Help for a Newbie! (Big scale)
by pdpdude 25/10/2022 20:30:51(UTC)
This page was generated in 0.545 seconds.
