Offline jonas_sthlm
#1 Posted : 06 October 2019 11:11:03(UTC)
jonas_sthlm
Someone who has heard something about new updates Cool
It seems that decoder tool sound database is crashed right now…
receiving incremental file list
sent 20 bytes received 58 bytes 52.00 bytes/sec
total size is 0 speedup is 0.00
sent 27 bytes received 502 bytes 352.67 bytes/sec
total size is 3,984 speedup is 7.53
The download is ended.
Offline TEEWolf
#2 Posted : 06 October 2019 20:03:05(UTC)
Which database link are you writing about?
mDecoderTool mDT3
https://www.maerklin.de/...undbibliothek-fuer-msd3/
standard sounds for mSD
https://www.maerklin.de/...-mldmsd/standard-sounds/
sounds for electric locos for mLD/mSD
https://www.maerklin.de/...r-mldmsd/elektro-sounds/
sounds for electric locos for mLD3/mSD3
https://www.maerklin.de/...mld3msd3/elektro-sounds/
Sounds for Diesel locos mSD
https://www.maerklin.de/...er-mldmsd/diesel-sounds/
Sounds for steamer mLD3/mSD3
https://www.maerklin.de/...r-mld3msd3/dampf-sounds/
factory settings
https://www.maerklin.de/.../standard-einstellungen/
please, note which decoder article number refers to which sound file.
Edited by user 12 October 2019 03:43:44(UTC)  | Reason: Not specified
Offline jonas_sthlm
#3 Posted : 06 October 2019 21:42:29(UTC)
jonas_sthlm
The one used that is built into the program to download Individual sound files and not completed projects.
Thanks for all the links...
Lots has happened after the release Sound library 26.06.2018
Offline jonas_sthlm
#4 Posted : 08 October 2019 19:21:00(UTC)
jonas_sthlm
Today everything works again ThumpUp
sent 371,039 bytes received 604,403,723 bytes 1,369,818.26 bytes/sec
total size is 603,034,428 speedup is 1.00
Offline jonas_sthlm
#5 Posted : 15 November 2019 09:29:09(UTC)
jonas_sthlm
Yesterday M publics a new version 3.4.0 and it's gone today on the download page Confused
thanks 2 users liked this useful post by jonas_sthlm
Offline bph
#6 Posted : 15 November 2019 11:28:17(UTC)
its still on the server:https://www.maerklin.de/fileadmin/media/service/decoder-updates/mDecoderTool3-v340-Setup.zip
CHANGELOG
Version 3.4.0 - 23.10.2019
- Feature: Create your own sounds, select your own sounds (wav, mp3) step by step, process them
automatically and sort them into the sound library (your own library)
- Feature: Decoder projects for all, for both retrofit and serial decoders, new display in mDecoderTool3
and storage structure on the Märklin server
- Feature: The mDecoderTool3 supports mLD track H0 for all-current/field-coil motor (60906)
- Improvement: Decoder with the Decoder-Programmer (60971) read out improved, communication
between mDecoderTool3 and the serial interface in Windows improved
- Improvement: Decoder (mLD/mSD, mLD3/mSD3) programmed and tested via central CS2 from v4.2.9
on revised, improved and optimized
- Improvement: Decoder (mLD/mSD, mLD3/mSD3) programming and testing via central CS3 from v1.4.1
- Improvement: New firmware is loaded from the Märklin server without having to create or open a project
- Improvement: Tooltips added to the dashboard functions
- Improvement: Added more missing status and tooltips in start, dash and detail boards
- Improvement: When a project is loaded, it is always switched to the dashboard, whether from the start
board or the detail board.
- Improvement: In the help menu, the manual of the mDecoderTool3 can be called up
- Improvement: Some CV names and texts in mDecoderTool3 and the decoder templates revised, unified
and provided with units and factors
- Improvement: The program directory has been restructured and cleaned up, texts and instructions as
well as languages and templates, etc.
- Improvement: In the mapping the fields of the actions are dynamically adapted to the window size,
helpful for long sound paths
- Improvement: For a better overview only the valid libraries and sound groups are displayed in the sound
library
- Improvement: The dialog windows can be moved freely with the mouse
- Improvement: The description files of a decoder project were updated (article numbers) and extended to
all functions and sounds.
- Bugfix: When converting the data structure (fds) to v3, the sound CVs brake threshold and brake
bandwidth are swapped, but the CV values were not swapped
- Bugfix: The Sound CVs Brake Threshold, Brake Bandwidth and Brake Deceleration Correction were not
saved after being read into an open project
- Bugfix: The sound CVs of the individual volume levels were displayed correctly but not saved correctly
after changing them
- Bugfix: In the sound selection the sound paths, to distinguish the libraries 'own library' and 'm library',
were not displayed correctly
- Bugfix: When installing version 3.3.0 the old and new decoder templates were not de- and installed
correctly
- Bugfix: In the 'Configure function keys' dialog, newly configured function keys were lost with the check
mark 'Show only active elements'
- Bugfix: If a decoder was programmed, the CVs of the project could be changed in the detail board,
despite the progress bar running, quasi 'behind it
- Bugfix: If a decoder was programmed, the buttons in the dashboard could be pressed 'behind' the
running progress bar
- Bugfix: If a decoder was programmed with a changed but not yet saved project, it was still programmed
with the old CV values after the hint dialog
- Bugfix: In the mapping was the on and off delay of the physics. Outputs (mLD3/mSD3) reversed
- Bugfix: Although no project was selected yet, it was possible to save it in the startboard with 'save' or
'save as
Offline jonas_sthlm
#7 Posted : 15 November 2019 13:17:38(UTC)
jonas_sthlm
yes but not public publish
I already see bugs and it may require a CS3 update Glare
Offline TEEWolf
#8 Posted : 15 November 2019 22:13:50(UTC)
Hello Jonas,
yesterday I wrote in another thread about Maerklin CS 3 software and its achieved version 3.4.1
https://www.marklin-user...---available-via-CS2-CS3
see post # 17.
Be aware, Maerklin differntiate between a mDT and mDT/3 programming but only using the term mDT for the programming stick.
For the mDT
https://www.maerklin.de/...mldmsd/mdecodertool-mdt/
and these software relates to different decoders. Read here:
"Download mDT (Märklin Decoder Tool)
This software is only suitable for retrofit decoders of the types mSD 60940, 60945, 60946, 60947, 60948, 60949, 60965, 60966, 60967 and mLD 60942, 60962."
and one for the mDT3.
https://www.maerklin.de/...3msd3/mdecodertool-mdt3/
"Download mDT3 (Märklin Decoder Tool)
The software mDT3 is suitable for the retrofit decoders of the new generation mSD3 60975, 60976, 60977, 60978, 60979, 60985, 60986, 60987 and mLD3 60972, 60982, 60983."
Both sites are only achievable via the German website from Maerklin. Please be aware about the article numbers of the decoders for the softwares usage.
Some more information about retrofit decoders.
https://www.maerklin.de/...ducts/new-items/decoder/
https://www.maerklin.de/...n/Leitfaden_online_E.pdf
Best Regards
Wolfgang
Offline TEEWolf
#9 Posted : 15 November 2019 22:39:09(UTC)
Which bug o you see? Which update of the CS 3 software shall solve the mDT/3 software?
Reading this Maerklin document
https://www.maerklin.de/...GB_ReleaseNotes_v340.pdf
I came to the conclusion, Maerklin has not updated its text on its website. Indeed the new mDT/3 software will be the version 3.4.0.
Offline jonas_sthlm
#10 Posted : 15 November 2019 22:57:42(UTC)
jonas_sthlm
The text was updated yesterday and gone today.
The CS3 reject receive to big size of files…
So it published in the wrong order.
Offline jonas_sthlm
#11 Posted : 26 November 2019 12:23:07(UTC)
jonas_sthlm
I get a update answer today by email..
It seem to be a CS3 update on its way soon and republishing of mDT 3.4.0 ThumpUp
Offline jonas_sthlm
#12 Posted : 06 December 2019 17:56:53(UTC)
jonas_sthlm
CS3 version 2.0.0 is out now ThumpUp
Lots of new stuff, connect more then one camera with IP number Drool
#13 Posted : 06 December 2019 18:24:43(UTC)
Harumph, the information PDF is only in German ... Huh
#14 Posted : 06 December 2019 18:30:57(UTC)
You have been a member since:: 12/08/2006(UTC)
Start google translate...Flapper
Offline TEEWolf
#15 Posted : 06 December 2019 19:43:18(UTC)
Interesting evolutions by this new update 2.0 for a CS 3.
But at the end of the CS 3 2.0 informations is an update information for a MS 2 too.
This update also includes an update for Mobile Station 2 (e.g. no. 60653 or 60657) from the previous version number 3.55 to the new version 3.112. ..."
Offline jonas_sthlm
#16 Posted : 06 December 2019 20:27:22(UTC)
jonas_sthlm
MS2 stability
Fixed a crash of the MS2
The cause of a crash in the MS2 was found and fixed.
Intensification Motorola locomotive search
For sensitive decoders, the process has been improved and the transmission of information has been quadrupled.
This page was generated in 0.510 seconds.
