Offline Thewolf
#1 Posted : 13 November 2019 18:08:01(UTC)
Thewolf
Hello guysCool
A few years ago the 74491 marklin engines had big problems with their limit switches.
To remedy this, we had to do this:
I know that a long time ago, I know that Marklin released a new generation of engines that should in principle have no problems.
I know all this... except... except... except I don't want to relive such an experience again.
My future layout will have 3 levelsc: 2 hidden stations and 1 top.
That's why I'm going to perform this operation on all the motors of the switches of the 2 hidden sations.
I'm assuming:.'''Better to prevent than to cure''.
What do you think of that?
Have a nice day
Thewolf
Project The Richelieu Valley Railway-CS2-Track C- Itrain-Digital
#2 Posted : 13 November 2019 19:45:29(UTC)
As long as you ensure that you don't leave the coils energised for longer than a few seconds I think it's an excellent idea. I wish I had done this on my layout....
Offline Thewolf
#3 Posted : 13 November 2019 20:36:54(UTC)
Thewolf
Thank you RayCool
These parts will only work for a few tens of seconds, there should be no problems
Thewolf
Offline Danlake
#4 Posted : 14 November 2019 09:01:43(UTC)
Danlake
Hi Thewolf,
I have done the same with all my switches regardless of version and year it was manufactured.
Best Regards
Lasse
Offline Thewolf
#5 Posted : 14 November 2019 13:35:18(UTC)
Thewolf
Hi Thewolf,
Best Regards
Lasse
Thank you Lasse Cool
For once, I made a good point on the forum LOL LOL
Thewolf
Offline wseltner
#6 Posted : 17 November 2019 13:51:38(UTC)
wseltner
Hello everyone. This issue was caused by a design fault. The original design did not have any capacitors to mitigate the back EMF when these little limit switch contacts opened on end of travel. The result is burnt contacts caused be the electrical arc created on opening. So after a few cycles there is enough of a burn to raise the contact resistance sufficiently to create an open circuit. I repaired all of mine by putting a 0.33 ufd surface mount capacitor across the outside terminal of the micro switch. Just cut out the unused center terminal of the micro switch and the capacitor fits in the space. I also added a 0.1 ufd capacitor across the coils. This required some very thin wire across the coil as there is no room. I also replaced the bad micro switches on mine. I still have all my original switch motors. Have never had a problem since
thanks 4 users liked this useful post by wseltner
#7 Posted : 18 November 2019 11:57:23(UTC)
Excellent!
As the design has changed at least 2 times, do we know if this design fault still exist in hte latest models? (i.e. if capacitors are now installed from the factory)
This page was generated in 0.723 seconds.
