Offline LNorthway
#1 Posted : 28 September 2019 21:39:00(UTC)
LNorthway
Have just purchased an old Marklin train set which sat in a steamer trunk for about 50 years. Just learning about the items. Have the engines running. Everything seems fine. Now trying to figure out the basic transformer #6440... it has an audible hum. Is this normal?
Also have a #6014 transformer (with a European plug). Everything in this purchase came from a friend who lived in West Germany when he was younger and moved to Canada about 40 years ago. Has not used the train since then. Cannot figure what the #6014 transformer might be used for. Noticed on the table on the front panel it is 50hz... therefore, I will assume it is for Europe only???
Looking forward to some comments! Thank you!
Lawrence Northway
#2 Posted : 29 September 2019 11:38:51(UTC)
Lawrence Northway
Hi Lawrence and welcome.
Generally the hum would not be a problem, many transformers do it, some more loudly than others.
But given the age, you should be aware of some safety issues, specifically the main cord as per this article...
https://www.marklin-user...me-a-huge-230-Volt-shock
Best to determine if your Trafo has an old & potentially dangerous rubber cord, or a more recent plastic cord. If in any doubt, have a professional check it for you.
#3 Posted : 29 September 2019 15:31:42(UTC)
My view is buy a new transformer (power pack) which will last for years and is safe and does the job properly.
Offline LNorthway
#4 Posted : 29 September 2019 15:52:40(UTC)
LNorthway
Thank you! Will toss the old one... the power cord was all rotted. Replaced it, and did not notice anything inside, but regardless, will just buy a new one! ... Lawrence
thanks 3 users liked this useful post by LNorthway
This page was generated in 0.482 seconds.
