Offline maico
#1 Posted : 11 September 2019 15:35:39(UTC)
maico
[img=http://UserPostedImage]motor5[/img]
[img=http://UserPostedImage]motor4[/img]
Guys I've got a running problem with a recent used purchase a Trix 22584 crocodile. This is the older version with only one powered bogie from around 2002.
The motor spins up smoothly applying power directly to any of the 8 axles, and it runs ok on curves too with no flickering from the lights, but on the straights it stutters and stalls on insulfrog turnouts.
I can't see any loose wiring or dirty pick-ups. Is there a known issue with shorts from the way the 2 bogies articulate ?
[img=http://UserPostedImage]motor3[/img]
[img=UserPostedImage]motor2[/img]
Offline maico
#2 Posted : 12 September 2019 16:17:14(UTC)
maico
OK, I think I've solved it. The small leading bogie had oil around the small plastic wheel insulating collar. Enough to cause a short with the axle which is live. All 8 axles pick up current.
Be careful with lubrication, it's likely a leading cause of lumpy running...
thanks 1 user liked this useful post by maico
Offline DTaylor91
#3 Posted : 14 September 2019 05:53:01(UTC)
DTaylor91
Odd, most oils are highly effective electrical insulators...
Offline maico
#4 Posted : 25 September 2019 11:28:47(UTC)
maico
Perhaps it's the intermittent nature of the insulation that was causing the problems ?
The running is better now but still not perfect( assuming this design was a good runner)
This page was generated in 0.329 seconds.
