Offline jeffooi
#1 Posted : 03 June 2019 03:49:22(UTC)
jeffooi
Its good to be joining the Marklin Community.
I recently binned my entire Hornby setup and retooled to 1960s Marklin analog.
My first engine is the model 3005: BR 23 with metal body. Looking at the Marklin Service Manual there are a number of smoke generators available but none specifically for the 3005. Doing a google search I found a few 3005 engines that were converted to smoke but no information on the products used. Can anybody point me in the right direction please?
Offline SteamNut
#2 Posted : 03 June 2019 04:07:22(UTC)
SteamNut
The 3005 has a plastic boiler therefore no smoke generator was ever offered. If you did see one it was a custom job as the the heat from the generator will melt the plastic boiler. I have heard that some people have done this, perhaps even on this form - Fred
Offline Pmare4
#3 Posted : 03 June 2019 04:49:26(UTC)
Pmare4
Originally Posted by: SteamNut Go to Quoted Post
The 3005 has a plastic boiler therefore no smoke generator was ever offered. If you did see one it was a custom job as the the heat from the generator will melt the plastic boiler. I have heard that some people have done this, perhaps even on this forum - Fred
Hi Fred,
That's not quite true - only the first version of the DA800 (the predecessor to the 3005) had a plastic boiler. Jeff's one will be metal.
Here's a link to some instructions on installing a smoke generator, written by another forum member:
https://www.marklin-user...-3005----Smoke-Generator
thanks 1 user liked this useful post by Pmare4
Offline jeffooi
#4 Posted : 03 June 2019 06:09:06(UTC)
jeffooi
Hi Peter and Fred, thanks for your replies. you beat me to it. Yes my 3005 has a metal boiler. I've asked for pictures of the soldering job.
To summarise that thread:
drill out chimney, (so long its a metal boiler),
solder a wire onto the bottom connection from the [smoke] generator to the shoe and solder that to the shoe pick up.
Total of 2 wires soldered underneath the shoe.
One to the engine , as is, and the second to the bottom tip of the [smoke] generator.
Jeff
#5 Posted : 03 June 2019 06:30:46(UTC)
Hello Jeff,
I too have this loco and the boiler, as you say, is made of metal. It is old ( ? 3005.8 : BR 23 - 014)
I have in the past contemplated that one could drill out the smoke funnel to take a smoke unit, but this remains on that long listSmile
PJ
This page was generated in 0.467 seconds.
