Offline ocram63_uk
#1 Posted : 10 March 2019 14:16:06(UTC)
ocram63_uk
Good afternoon,
not being able to find smoke fluid at my local shop and wanting to try eCig fluid I gave it a go.
The brand of fluid I tried does not work, no smoke, no nothing.
Now, the question I have is HOW do you suggest cleaning the smoke units ?
Blowing into them ?
Running them under the hot water tap ? Obviously removing them fro the loco first :-)
Other ?
Thank you and sorry for this silly trial :-)
Have a nice Sunday afternoon
Offline michelvr
#2 Posted : 10 March 2019 14:31:41(UTC)
michelvr
Good afternoon,
Blowing into them ?
Other ?
Marko are you sure your name isn't: Loco: Out of one's mind; insane; crazy! You obviously belong to the “Rookie Darwin Awards club” The Darwin Awards salute the improvement of the human genome by honoring those who accidentally remove themselves from it in a spectacular manner!
Whatever has gotten you to do something so stupid as to use eCig fluid in a steam locomotive?
What next stand on the tracks to dry your hair when the train passes by!
Maybe I’m too hard on you but come on WTF were you thinking?
Offline ocram63_uk
#3 Posted : 10 March 2019 14:42:39(UTC)
ocram63_uk
I'll consider this satire.
But a pointless answer as well BigGrin
Offline michelvr
#4 Posted : 10 March 2019 15:29:35(UTC)
michelvr
Yes very silly trial.
I was mainly stating the obvious which you obviously don't seem to understand. How embarrassing to post such a question. Stupid is as stupid does! It means that an intelligent person who does stupid things is still stupid. You are what you do! This is a Marklin-users.net forum which means to foster knowledge and ideas between like minded people. Your question and reply speaks volumes of your personality and lack of reasoning. What made you think to use eCig fluid as a substitute for the real smoke fluid?
Offline ocram63_uk
#5 Posted : 10 March 2019 15:55:28(UTC)
ocram63_uk
Apart from not being 'stupid', maybe the idea it is per se, but smoke fluid and eCig fluid work on the same principle. You heat a fluid and this makes smoke, one you inhale and the other comes out of a smoke stack.
I don't believe this is a problem if it works. It hasn't worked out. With all the eCig fluids out there there could be one that is ok for Seuthe units.
My request was very simple, how do you clean the smoke unit, not rocket science. If you do not know the answer then just say so.
Like minded people, you say ? What if it had worked ?
Imagination is more important than knowledge, Einstein once said. I don't pretend to be like Einstein but I've got plenty of imagination and I like to try out 'new' things. Who says it is wrong ? Does this make me stupid ? I don't believe so,
I don't label people just for the sake of it. Enjoy your un-imaginative Sunday afternoon BigGrin
thanks 2 users liked this useful post by ocram63_uk
Offline PMPeter
#6 Posted : 10 March 2019 15:56:24(UTC)
PMPeter
I think this needs to be notched down a bit.
We all do trials using various substances. Some work, some don't. So that doesn't mean a person needs to be called names and be put down for trying something, especially when admitting it was a mistake and asking for suggestions how to fix the mess he made. After all Canadians have a reputation of being polite!
Now to the question. I would, as you say, remove the smoke unit, wipe it out with a Q-tip and then use a mild detergent mixture to wipe it out again followed by a clean water wipe out. Not knowing what e-cig smoke fluid is based on, this may or may not work and hopefully someone else has a more definitive answer.
thanks 8 users liked this useful post by PMPeter
Offline scraigen
#7 Posted : 10 March 2019 15:59:36(UTC)
scraigen
He who asks a question is a fool for five minutes; he who does not ask a question remains a fool forever. – Chinese Proverb
No reason to be embarrassed about asking a question on here, I would just give it a rinse with WD40 or Isopropanol (alcohol), although others may be able to give much better suggestions as to cleaning of smoke generators.
I thought it was quite a reasonable thought to try eCig fluid!
Must build something
thanks 5 users liked this useful post by scraigen
Offline michelvr
#8 Posted : 10 March 2019 16:07:39(UTC)
michelvr
I agree I am being very hard on Marko, my sincere apologies Marko!
ECig fluid:
The liquid is made up of a solvent, either glycerol or propylene glycol, nicotine, and often food-grade flavourings. ... Although the food flavourings are in themselves safe when used in food (as are the solvents) that does not mean they necessarily are entirely safe for a different use, such as in e-cigarettes.
Online kiwiAlan
#9 Posted : 10 March 2019 16:25:49(UTC)
I would suggest doing the following - fill a seuthe smoke fluid syringe with some isopropyl alcohol (rubbing alcohol). Then hold the loco upside down and squirt the IPA into the smoke unit and let it drain down onto a paper towel as you squirt the IPA in. This should be enough to wash out the ecig fluid.
I would work on filling the syringe with 5-10 ml of IPA, which when flowed through the smoke unit at the rate you can squirt it in should be enough to give it a spring clean.
Offline SteamNut
#10 Posted : 10 March 2019 17:39:34(UTC)
SteamNut
We have all done things that can considered stupid or regrettable in the past. Hopefully we never do them again. I myself was cleaning my track with a electronic cleaner and did not read the instructions which stated that it was flammable until it was dry. When I was testing the track a spark from the lok started a fire. Luckily I lost only two turnouts and five signals. Anybody else care to own up what they did? It might be interesting to read - Fred
thanks 5 users liked this useful post by SteamNut
#11 Posted : 10 March 2019 20:48:30(UTC)
I don't think it was a stupid test, I've been thinking about the same for some time; but haven't done the test YET Cool
#12 Posted : 10 March 2019 21:45:41(UTC)
....this makes smoke, one you inhale and the other comes out of a smoke stack.
Sometimes I inhale (not intentionally) the smoke that comes out of the smoke stack....
Does that mean you're not stupid YET, but will be soon....!? Flapper
#13 Posted : 10 March 2019 22:35:37(UTC)
Probably yes LOL
#14 Posted : 10 March 2019 23:39:20(UTC)
The fire authorities in Pers region have been alerted. Excess smoke in no cause for concern its just a steamer on a model rail layout.
It has been noted that people are now buying Marklin smoke fluid to us in their Ecigs which will help Marklins profits. ESU said they are considering the matter and the facility will be added to their control system. PIKO are producing a special Ecig loco complete with fluid at half the price but Brawa say they have no idea what we are talking about as they don't smoke.
Here in Scotland we are using the fumes from the peat bog … supplies of peat are available for small fee.
thanks 4 users liked this useful post by David Dewar
Offline ixldoc
#15 Posted : 10 March 2019 23:51:38(UTC)
ixldoc
Don't forget to remove the central pipe and run it through with the fine spring wire supplied by Seuthe.
Offline ocram63_uk
#16 Posted : 10 March 2019 23:58:46(UTC)
ocram63_uk
Hi guys, thank you very much for your replies and suggestions, much appreciated.
Speaking of isopropyl alcohol (rubbing alcohol) is it possible to buy it in any supermarket / over the counter in England or I have to go to a chemist ?
No offence taken for anything said on my trial LOL
Have a nice week
Offline LongHairedDavid
#17 Posted : 11 March 2019 11:53:51(UTC)
LongHairedDavid
Have a nice week
I bought a litre for £9.99 off Amazon delivered next day!
Long Haired David
AKA David Pennington
A mystified Maerklin Newbie
thanks 1 user liked this useful post by LongHairedDavid
Offline ocram63_uk
#18 Posted : 11 March 2019 14:07:39(UTC)
ocram63_uk
Hi David,
thank you very much !!!
M
#19 Posted : 11 March 2019 17:31:12(UTC)
Hmmm... I think it is actually very apluadable to have made this test.
If it wasnt for "stupid" tests made by brave people, we would all still be living in caves.
Just think of all those black-and-white movies with people trying different VERY STUPID ways of taking off in would-be flying machines.
They are laughable, yes, because we now know so much more.
But HOW do we know so much more? It is THANKS to these endless trials and errors, made by that people!
I dont think it is such a stretch thinking that smoke fluid and cigarette fluids could share common properties. Aren´t they based on the same principles???
I´m definetly tipping my hat for ocram´s tests!
#20 Posted : 11 March 2019 21:25:22(UTC)
Why a silly trial? Both are substances that produce a smoke when heated up.
Both are substances that in vapor form are not healthy to inhale.
Your suggestion that the experiment was doomed to failure and a person undertaking it a fool is off base and not productive.
#21 Posted : 11 March 2019 22:06:17(UTC)
I don't think we need to call each other names, but yes it was a silly thing to do! We all do silly things occasionally, and this is probably a good example. If we don't like the word silly we could try "Ill advised".
Although some of you have thought it admirable that someone should try things at random to see if it works, as a person with scientific and engineering background I can tell you that that's not how things are invented or discovered. That is more how people are killed and seriously injured! Knowledge is advanced through research and experimentation based on scientific principles.
In this case Ocram would have done better by asking the question in the forum before trying his experiment!
#22 Posted : 11 March 2019 22:39:54(UTC)
Are you talking about human flying machines or smoking toy trains now??? BigGrin
#23 Posted : 11 March 2019 23:24:27(UTC)
Who would know the answer?
Offline Rwill
#24 Posted : 11 March 2019 23:49:00(UTC)
Rwill
I am totally puzzled by this thread. A simple search of this forum for "cigarette smoke" shows that the subject has as I thought come up at least twice before dating back a year or more and including being raised by my learned friend Ocram. It was muted as "an idea" and most seemed to think it had possibilities but OK no one admitted trying it but equally no one expressed a view on the possible hazards and consequences and questioned the sanity of the suggestion. Am I missing the point as normal?
thanks 2 users liked this useful post by Rwill
Online kiwiAlan
#25 Posted : 12 March 2019 00:12:53(UTC)
I don't recall e-cig fluid being suggested before (but then again I haven't searched the archive), but I do recall some discussion on the possibility of using the fluid that is used for smoke machines for stage use. I don't recall if anyone has actually tried this, but I have a source and want to try it at some stage.
I have also heard of someone trying valve oil as used for lubrication the valves on brass musical instruments. This is a very light oil and was apparently quite successful as a smoke oil.
#26 Posted : 12 March 2019 20:16:30(UTC)
And yet there is a strong case for experimentation and accidental discovery:
https://www.sciencealert...veries-changed-the-world
Microwave Oven, Prevention of Malaria, X-Rays, Velcro, Radioactivity, Artificial Sweetener, Heart Pacemaker, Penicillin, Insulin, Vulcanized Rubber, Super Glue (CA glue) and may more.
thanks 4 users liked this useful post by Minok
#27 Posted : 12 March 2019 20:27:56(UTC)
Why is it silly? So far I'm only reading its "silly" by definition, because they "said so". No explanations on why one could logically conclude that it would be a foolish or silly thing to try on its face.
If you look on YouTube there are quite a few videos on using e-cig or vape fluid for generating smoke in model railroads. That by defintion indicates that the idea is not silly, but quite plausible and usable in certain conditions. Now whether it works as a drop in replacement into a Seuth loco smoke generator is another question... and one that is best answered by the very experiment that was undertaken.
(no scent or nicotine varieties also available)
And on Stummi they also tried at various times; its a natural experiment to any model railroader who had happened to switch to E-Cigs at some point and thought wait a minute....
The thread here, the experimenter found the viscosity of e-cig fluid was a bit too high so he thinned it with good old SR24 first... at a 2 vape liquid to 1 SR24 ratio.
So the experiment here may have failed just due to viscosity, or it could be the Stummi user's result was due to the SR24 vaporizing and the flavored vape fluid was just coincidentally going along on the ride.. One would have to experiment and carefully observe the level of smoke vapor to know.
https://www.stummiforum....ic.php?f=21&t=113852
#28 Posted : 12 March 2019 20:32:55(UTC)
None of these were discovered by mixing random liquids in a test tube!
Sometimes things are invented or discovered by unexpected results to an experiment for a different purpose, but there is always a scientific method being followed.
#29 Posted : 12 March 2019 20:33:34(UTC)
You have to try unconventional stuff now and then, and learn from it - like Marco's smoke fluid test...
Did try myself to clean a greasy 3106 by dipping the chassis in alcohol - the result was red alcohol and fingertips as well as a pinkish chassis since the red paint dissolved... Lesson learnt... BigGrin
Without daring experiments we would not get new viable ideas and just rely on the old catalog numbers in our comfort zone... Cool
thanks 9 users liked this useful post by Webmaster
Offline dickinsonj
#30 Posted : 13 March 2019 03:09:41(UTC)
This was definitely discussed before on the forum, in fact multiple times. The general consensus was that it would probably work and that it was an interesting idea.
Now someone tries it and shares a less than perfect outcome and he is an idiot. That seems uncharitable to me and outside the normal concept of an online forum, which is to share new and interesting ideas.
I would use isopropyl alcohol and clean the small tube with the wire provided and move along. I often regret the things that I was afraid to try more than those which failed.
Offline dominator
#31 Posted : 13 March 2019 03:13:58(UTC)
dominator
What was it that Forrest Gump said [ something like stupid is ....... ].
Maybe we should have a Forresst Gump thread where we can have a laugh at the silly things we have done in the past. If we are brave enough to admit our cockups. Didnt Henry Ford say " A man who never made a mistake, never made anything ". He also said "History was bunk' so we can take that with a grain of salt as well.
Dereck
Offline skeeterbuck
#32 Posted : 13 March 2019 11:34:07(UTC)
skeeterbuck
I don't see how it was a silly experiment either. It's plausible that it could work but in this case it didn't. I've read here that some use Blue Juice valve oil that made for I think musical instrument use. I sure it was "discovered" by just giving it a go and seeing if it would work.
My only suggestion is that when you experiment with different "mixtures" that you use a spare smoke unit on your bench. That way if it doesn't work, you can easily clean it out and if for some reason you would ruin the unit, then you wouldn't have the hassle of having to replace it in the loco.
Chuck
thanks 1 user liked this useful post by skeeterbuck
#33 Posted : 13 March 2019 14:04:15(UTC)
There's no shame in doing something silly. The cleverest people sometimes do the silliest things!
My only worry is that sometimes people experiment with substances that can be dangerous or can ruin something expensive, like a Marklin locomotive!
My advice would always be that if you are tempted to try something unusual it's best to either ask someone who might know or research it on the internet. As my lecturers used to say all those years ago, "Don't re-invent the wheel!"
#34 Posted : 14 March 2019 12:00:01(UTC)
Agree with that. Also before posting on our site might be good to ensure what it is has been tried and found to be working and not in any way dangerous to locos or us.
#35 Posted : 14 March 2019 19:33:00(UTC)
He wasn't throwing random liquids into the smoke generator either. Its pretty basic scientific principle to do an experiment (with a substance known to smoke when heated, as that is its purpose for the most part), and observe he results.
#36 Posted : 14 March 2019 20:35:35(UTC)
Virtually every substance will smoke when heated. Some substances require more heat than others.
However it is clear that my pleas for research and consultation before experimentation are not viewed sympathetically, so I will refrain from putting forward my opinion any further. I never meant to ridicule the OP for his 'mistake', and I have stated before that I accept that silly mistakes happen to anyone. Perhaps I am more 'risk-averse' than many others....
I won't follow this thread any more.
#37 Posted : 18 March 2019 20:02:57(UTC)
A friend of mine just did a test, using eCig fluid in an ESU smoke generator, sitting in a 1-Gauge Nohab:
The best result comes when using pure VG ( Vegetable glycerin )
Offline ocram63_uk
#38 Posted : 23 March 2019 23:15:08(UTC)
ocram63_uk
I found isopropyl alcohol at one of the chemists in town. I also managed to buy a syringe with needle, although they weren't very keen to sell it to me as it is 'dangerouos'.
Anyway I washed the smoke generator with a few squirts of alcohol and filled it with Dapol smoke fluid. The loco smokes again although I think that the Dapol smoke fluid is too 'heavy'.
All is well that ends well
This page was generated in 1.482 seconds.
