Offline phyan
#1 Posted : 19 February 2019 16:48:21(UTC)
phyan
A long time ago (actually, quite exactly 10 years ago) there was a discussion about preventing problems with the contact track:
https://www.marklin-user...51-Contact-track-sensing
I have read this interesting article and the studied the solution many times, but it remained unclear to me, how to really employ the Zener diode. Could someone explain this once more, please. And in a way suitable for dummies as well :) Where in the system shall you put the diode, and are there other components you need, too? A diagram would be just awsome, thanks. -M.
thanks 1 user liked this useful post by phyan
#2 Posted : 19 February 2019 17:34:05(UTC)
Hi xx
Welcome to the forum.
This is a current-sensing schematic for DC 2 rail based on only one pair of diodes (simple rectifier diode) the third diode is not a zener but identical to the other two to drive the transistor base. So simply use the schematic for a DC layout. For AC 3 rail this schematic is not applicable but rather connect one of the -previouslyinsulated- rails to the S88 entry
Offline Danlake
#3 Posted : 19 February 2019 19:20:07(UTC)
Danlake
As I understand you are talking about the trick of installing a diode when using isolated contact track section to improve the ground return in 3 rail operation.
I haven’t found it necessary on my layout but can be advantages especially with locos with limited ground wheel return.
Dale wrote this excellent guide:
http://members.ozemail.c.../pdf/the_diode_trick.pdf
And from forum:
https://www.marklin-user...-feedback-and-diodes-etc
Best Regards
Lasse
#4 Posted : 19 February 2019 20:43:27(UTC)
What he said....
There is a diode trick for the S88 sensing tracks but it is only needed to address a small subset of locos/rolling stock that have very short wheel base with limited ability to contact the two tracks...
Offline phyan
#5 Posted : 20 February 2019 09:01:57(UTC)
phyan
Thanks everybody for pointing to these information sources, it was very interesting and helpful!
- Matti
Offline rrf
#6 Posted : 23 February 2019 14:28:30(UTC)
rrf
Views messages in topic : 300
<Stuff Deleted>
I am about to setup my first S88 Contact Track sections. I have quite a few of the "small subset" of loks, including four E69s. So I plan to use diodes to improve conductivity on these track sections.
Rather than mount the diodes near the S88, I would like to install them on the underside of my C-Track, in the approximate center of each the isolated section. For flexibility I am planning to solder a bit of brown wire on each end of a 1N4002 diode and then connect it to the track using 74995 spade connectors.
Does anyone foresee a problem with this?
Rob
Mackenrode Wende Bahn
#7 Posted : 23 February 2019 14:59:01(UTC)
Hi Rob
I would avoid installing components under the track if they are fixed and ballasted.
I am sure you know the cathode is to be connected to the contract track section
rrf
Offline rrf
#8 Posted : 23 February 2019 15:09:14(UTC)
rrf
Hi Rob
Hello Jean,
Thank you for your reply.
The track will not be ballasted or fixed. Since I tend to change my layouts regularly, I prefer to rely upon gravity and friction. As to the diode's cathode, I had a subsequent thought of color coding the wire (grey on one side and brown on the other) to make sure I don't reverse the connection. I plan to use the same for the common ground (brown) and S88 connections (grey).
Rob
Offline Elsleuth1
#9 Posted : 23 February 2019 15:15:31(UTC)
Elsleuth1
I have 16 S88's and they all work perfectly without an added diode. But I am interested in specifically which cars or locos would need a diode to trigger an S88. If a car or engine doesn't trigger the S88 wouldn't the next car do the job?
#10 Posted : 23 February 2019 15:29:31(UTC)
As you know the S88 is very high impedence with a pull-up resistor to +5 V and cannot feed any loco so any loco with only 4 wheels of which one is a traction tire is a good candidate: Schienenbus, kittel. Robel, etc
Offline Elsleuth1
#11 Posted : 23 February 2019 15:36:52(UTC)
Elsleuth1
Very interesting. So a Rail Bus would be a excellent candidate for a problem and because it has four wheels and often goes between two S88s.
Offline rrf
#12 Posted : 23 February 2019 15:57:25(UTC)
rrf
I am most worried about my E69s: two axles within a couple centimeters of each other. Using the diode, in theory I reduce the chance of stalling by at least 50%.
Rob
thanks 1 user liked this useful post by rrf
Offline PeFu
#13 Posted : 23 February 2019 20:11:25(UTC)
PeFu
I use the configuration presented by LDT, see below. I asked Mr. Littfinski on why they recommend a BY251, and he responded:
”The 1N400x diodes are for a maximum of 1 Amp current. During a short circuit condition, the current trough the diode could be much higher. Therefore we recommend the BY251 for a maximum of 3 Amp current.”
thanks 4 users liked this useful post by PeFu
Offline rrf
#14 Posted : 23 February 2019 21:09:22(UTC)
rrf
That makes perfect sense. Actually I have been looking thru Digikey for a suitable 3 amp rated diode. Since I am not an EE person, the BY251 code you provide made matters much easier.
Thank you!
Rob
#15 Posted : 23 February 2019 22:32:22(UTC)
Thank you!
There is also a 3A version of the 1N400x family, but I can't remember the number off hand.
Offline rrf
#16 Posted : 23 February 2019 22:58:26(UTC)
rrf
I ran across the various 1N400x diodes, including ones rated for 3 amps of "Rectified Current". It was the other parameter choices such as "Forward Voltage" and "Reverse Current Leakage" that complicated my choice. Having a specific component recommendation for my desired MRR application makes me feel better.
Rob
This page was generated in 0.945 seconds.
