Offline Philh58
#1 Posted : 02 February 2019 01:09:45(UTC)
Philh58
Hello all,
Ive just purchased a Trix SBB Seetalbahn De6/6 item code 22536.
Plan is to convert to DCC and run using my lenz system.
It’s my first Trix model so I’m looking for advice as to what decoder I can use. I don’t have any vendor preferences and I’m not bothered about sound.
May thanks...
Offline mbarreto
#2 Posted : 02 February 2019 01:51:39(UTC)
mbarreto
Originally Posted by: Philh58 Go to Quoted Post
Hello all,
May thanks...
If you can wait a bit, I would wait for an ESU LokPilot V5 multiprotocol (no sound), or an ESU LSM4v5 (sound).
If you don't want to wait you can go for any ESU v4 or Märklin Mxd/3.
Miguel
Mostly Märklin H0.
Offline TEEWolf
#3 Posted : 02 February 2019 03:05:25(UTC)
Hello all,
May thanks...
I am only using Märklin and not very familiar by Trix. But as far as I see, your loco has a Selectrix-Decoder 66837
https://www.trix.de/en/p...s/details/article/22536/
scroll down to features to see it.
Here you find the manual and more about this decoder
https://www.trix.de/en/p...s/details/article/66837/
and in its manual
https://static.maerklin....f2f10396021434535682.pdf
In the manual stands this decoder can be run under DCC too with a digital controller. You need a MS or a CS or a similar controller for running the loco under DCC. You have to add your loco manually to your controller under DCC (on a seperate programming track) and then it shall run.
A few more technical featuers about your loco (even it is unfortunately only in German)
http://www.mobadaten.inf...De_6/6_Elektrolokomotive
and decoder
http://www.mobadaten.inf...C3%BCr_NEM_Schnittstelle
Use the decoder which is already inside. A conversion to DCC is not necessary.
Offline PeFu
#4 Posted : 02 February 2019 07:52:13(UTC)
PeFu
...or e.g. a Lenz system. Smile
#5 Posted : 02 February 2019 08:25:11(UTC)
If you are running DCC then use ESU to get the Railcom Plus support.
#6 Posted : 02 February 2019 15:00:56(UTC)
ESU are not doing a Lokpilot in the V5 version. After all why would they need to?
They advantages of the v5 all improve the sound functions, but the motor drive functions of the V4 are already pretty magnificent.
Offline mbarreto
#7 Posted : 02 February 2019 18:26:12(UTC)
mbarreto
Right, thanks for the correction. When I read the Loksound V5 information, somehow I got the idea they were also going to produce a LP V5. So instead of LPv5 it is LPv4 M4 or LPv4 M4 MKL.
Miguel
Mostly Märklin H0.
Offline Philh58
#8 Posted : 02 February 2019 19:01:17(UTC)
Philh58
Thanks all for your advice, much appreciated.
I’m a little confused by TEEWolf reply which indicates it’s all ready got a decoder. I’ll take body off and confirm
#9 Posted : 02 February 2019 19:30:02(UTC)
Yes, I don't know what the difference with the MKL version is, except it is a bit cheaper, but it still seemed to have all the protocols still. I could understand it being cheaper if it had only MM and M4.
Offline TEEWolf
#10 Posted : 02 February 2019 20:54:19(UTC)
Yes this will be very helpfull. A lot of members throw you names of decoders around your ears. I do not think you really understand this all, what they are writing you about it. Wheras the TRIX website for your loco #22536
says under section "Features"
"Small digital connection (Selectrix-Decoder 66835/66836)". What else as a decoder shall this be? Nobody here has written anything about this most important feature. But if this is a decoder why will you change it? Even if you do not know yet anything about the possibilities of such a decoder. This is shown in my other link
https://www.trix.de/en/p...s/details/article/668361
Both links offer manuals for further informations.BigGrin
Offline mbarreto
#11 Posted : 02 February 2019 21:19:41(UTC)
mbarreto
The MKL is the one that have the AUX outputs (AUX3 and AUX4) with voltage and power levels above the TTL levels as specified by the NEM norms.
Märklin in some of their locomotives uses decoders that have these outputs (AUX3 and AUX4) with voltage and power levels that are the needed ones for activate TELEX couplers and smoke generators for example. The ESU decoders that are not MKL have AUX3 and AUX4 with TTL voltage levels, so they need a power stage in front to drive TELEX, etc.
Miguel
Mostly Märklin H0.
Offline Crazy Harry
#12 Posted : 03 February 2019 01:07:40(UTC)
Crazy Harry
It seems to me that it only has the connection for the decoder since under the digital features it says nothing. Therefore, a decoder is still required but 66835 and 66836 don't seem to exist anymore. Someone with more experience will have to suggest which decoder will work for you.
Harold.
This page was generated in 0.750 seconds.
