#1 Posted : 15 November 2018 15:35:54(UTC)
Hi in anticipation of Santa bringing my CS3 Plus I purchased the new power pack and also a 60881 S88.
I am aware the 60881 connects directly to the CS3 PLus. However with the decoder there is blue cable and on the decoder there are two sockets for connecting to other S88s. Where does this blue cable go in the S88 in order to connect to the S3 PLus.I presume this cable is all I need and does it just go into one of the S88 sockets used for other S88s and then to the CS3 Plus.
Thanks for any info which I cant find in the instructions or the Marklin book on the CS3s
Offline siroljuk
#2 Posted : 15 November 2018 17:03:25(UTC)
siroljuk
Hello.
Just turn your CS3Plus upside down there is socket for that blue cable.
Be sure you put the cable to s88's right socket. Read more from manual of S88
Jukka
#3 Posted : 15 November 2018 17:31:38(UTC)
Hi Thanks for that. The manual does not indicate where to plug in the cable to the S88 for connection to a CS3 Plus. However will put this into the one on the right (depending which way you are looking at the S88!!) Thanks for help.
David
#4 Posted : 15 November 2018 20:21:56(UTC)
Just like on the 6088/60880 the arrow (triangle) points "towards" the controller
This page was generated in 0.323 seconds.
