Offline stockerta
#1 Posted : 14 October 2018 09:38:44(UTC)
stockerta
Hungary
I use currently one 7039 to control two trains on my layout with two 5146-es, but for reliable operation I know i need at least 3 (number of locos + 1).
My question is, that one 5146 can be used two switch two signals simultaneously. One to green and the other to red, or I need a pair of 5146s for each signal?
Offline Markus Schild
#2 Posted : 14 October 2018 10:28:52(UTC)
Markus Schild
Yes, a 5146 can switch two and also four solenoids simultaneously. But you should make sure that there is a sufficient power-source. Calculate 8-10VA to switch a signal. So you must have at least 16VA capacity in the moment of switching. To run an illuminated train and trying to switch two solenoids from a 30VA transformer will not be reliable.
Markus
Offline stockerta
#3 Posted : 14 October 2018 10:51:30(UTC)
stockerta
Hungary
Thank you.
It seems then that I'm better of at the moment with two separate tracks for switching. In the long term I want to get multiple transformers for the different tracks and lightning.
This page was generated in 0.306 seconds.
