Offline Jabez
#1 Posted : 14 August 2018 01:01:05(UTC)
Jabez
Apparently it is sometimes necessary to change the wheelsets on some Piko and Lilliput wagons/coaches for them to run trouble free on Maerklin tracks.
What is the situation with Piko and Lilliput locos on Maerklin tracks. Do they run OK or are there problems with the wheels?
Jabez
Offline DV
#2 Posted : 14 August 2018 04:25:08(UTC)
DV
They say a picture is worth a thousand words........so how many words for a video....or two.....or three............BigGrin BigGrin BigGrin BigGrin .....please excuse the lousy camera work.
Can't say how the Liliput locos travel on Märklin track, but here are a few videos showing differnt types of Piko locos travelling on C and M track.
No problems have been encountered......so far, and the videos date back to 2011.
Hope this answers your question
C track
New club layout (8m x 5m) through points and double slips
New Modular layout (6m x 5m) through ballasted C track, points and double slips
Old modular layout (10m x 4m) through ballasted C track, points and double slips
Old club layout (3m x 1.5m) lots of curved points
M track
Private (Mike's) Layout did go through the hand operated points without any problems, the only problem was a digital loco working on analogue and not running smoothly with power interruptions.
Dusan V
thanks 3 users liked this useful post by DV
#3 Posted : 14 August 2018 07:38:38(UTC)
I converted a Piko loco to three-rail operation and, as expected, I had to replace the wheelsets. Appropriate AC wheelsets were available from Piko.
I never had problems with Piko or Liliput locos that were sold for the three-rail system ex works. They come with the appropriate wheel spacing out of the box.
So buy three-rail locos or be prepared to adjust or replace the wheelsets.
#4 Posted : 14 August 2018 20:11:44(UTC)
I have both Piko and Liliput 3 rail locos and found that they run perfectly on M track and C track.
Offline sjbartels
#5 Posted : 15 August 2018 03:08:10(UTC)
sjbartels
I'm with Ray on this, I have four Piko loco's, granted they're factory AC three rail, but never had a problem with them on Marklin track - both M and C track
They're rolling stock, I have quite a number of 4 axle Piko tank cars, with DC wheels never had an issue either.
thanks 1 user liked this useful post by sjbartels
#6 Posted : 15 August 2018 04:28:25(UTC)
I have had a few issues with other brands, but I do not think that it is because of the wheelsets. In most cases, the problems occurred when lighter coaches or cars were inserted into a consist and the weight of the cars behind caused the lighter coach to pop off the tracks in a curve. I have also seen very rare instances where the buffers of some models interfere with the couplings or with the buffers of the adjacent car, causing the car to tip to the side. The solution in such cases is to place the lighter cars at the rear of the train so there is less drag on the car from the cars behind or in case of buffer issues, to switch to other couplings that do not impact on the buffers or provide more space between cars.
Most manufacturers do make AC wheelsets, so if you experience any issues, you can replace the OEM DC ones with the appropriate AC ones. This is especially important if you use the track to activate devices as the AC wheelsets allow the activation of the trigger section, which does not occur with isolated DC wheelsets.
A number of manufacturers authorize dealers to swap wheelsets on delivery. You can specify AC when placing your order and see if the dealer will swap them out.
As far as safe operation, I would be concerned about possible issues with wheelsets with DC spacing on M Track (especially older variants), but this should not be an issue on K Track or C Track.
For cars and coaches with power collection from the wheels, it is often possible to obtain the L and R rail contacts on the bogie by inverting one of the wheelsets per bogie, which will then have contact with both L and R rails
#7 Posted : 15 August 2018 07:56:23(UTC)
In my experience derailment problems in curves can often be blamed on couplers, derailment problems on turnouts can often be blamed on wheelsets - but couplers can also be the problem here.
People often blame derailments on light-weight third-party products, but in my experience a full investigation will sometimes find that the wheel spacing or the couplers are the problem.
My problem investigation guide would be:
  • Make sure you do not use Märklin couplers - neither on third-party rolling stock nor on rolling stock coupled next to it
  • Make sure the wheel spacing is small enough
  • Make sure rails are aligned
  • If all else fails, consider adding weight (I never had to do that Wink )
See also:
http://blog.mailez.de/eb...-couplers-for-h0-models/
#8 Posted : 15 August 2018 10:39:43(UTC)
I have changed the wheelsets on some of my Piko and Liliput rolling stock as they sometimes do not go through turnouts properly. This is most apparent on long wheelbase wagons and less so on bogie wagons and coaches.
Couplings need to be "trial and error" on individual wagons. I have found that the Marklin close couplers work fine on most of my Roco and Piko wagons and less so on the Liliput ones. I prefer as far as possible to keep to the Marklin couplers as many of the NEM couplers from other brands are incompatible with the Marklin ones.
#9 Posted : 15 August 2018 12:36:26(UTC)
Hi Ray,
In my case, also on K-track for Piko locos.
Philip
Offline dominator
#10 Posted : 15 August 2018 13:11:14(UTC)
dominator
I agree with what is said above. I have M track and have had problems with 2 rail wheel sets and the buffers one some rolling stock, namely Roco and Trix. Following on this forum, I realized the DC wheels sets were too wide for Marklin so followed the advice of pushing the wheels closer to get the right gap. I then found that some wheels have smaller cross sections than Marklin so derailments were happening because one wheel would in some case slide down between the rails. [ I experimented on a couple by adding some epoxy resin to some wheels to make them wider and that cured that problem.] Weight is an issue on the very light rolling stock also as mentioned above, so the answer is either add weight or put them at the rear of the train. I have never had anything other than Marklin Locos , so looking at the above comments, it appears the other brands made especially for three rail obviously have three rail wheel sets, Two rail locos probably have DC wheel sets which will most likely be a problem on Marklin M track. [ Could that be because the latest Marklin tracks have solid rails with flat top surfaces as apposed the the tin forms of the M track which has rounded top surfaces? ]
Dereck
Edited by user 16 August 2018 12:11:11(UTC)  | Reason: spelling as usual
thanks 2 users liked this useful post by dominator
Offline sjbartels
#11 Posted : 19 August 2018 04:39:19(UTC)
sjbartels
I have quite a number of Piko 4 axle tank cars, the longer ones, as I said before and I proactively replace the wheels with AC wheels and the couplers with Marklin short couplers, just so I can interconnect Marklin and Piko together because, like you said, other ones (Like Piko), do not play well with Marklin couplers. Even in the ones that I didn't trade the DC wheels out right away (because I was waiting on more), I didn't have a problem with.
thanks 3 users liked this useful post by sjbartels
This page was generated in 1.049 seconds.
