Offline poppa-7
#1 Posted : 30 July 2018 00:04:37(UTC)
poppa-7
Dear fellow Members
I need a bit of help the a 3309 smoke unit wiring. Hi
I am fitting a 66031 delta decoder to my 3309 4-6-2 steam loco and I wondered if you could tell me where to solder the smoke wire to on the decoder.
Thank you
RussellConfused Confused Confused
Offline mvd71
#2 Posted : 30 July 2018 09:59:16(UTC)
Hi Russell,
With a 66031 decoder you will need to connect the smoke unit directly to the pick up shoe. It will be powered continuously, but that is a limitation of the decoder you have.
Cheers.....
Offline Markus Schild
#3 Posted : 30 July 2018 12:14:38(UTC)
Markus Schild
Hi Russell,
The 66031 has one switchable function which can be also used for the smoke - generator. But that function is not switched like usual on the control-pad. It is switched in a sequence with the direction:
Forward off - Backwards off- Forward on - Backwards on - Foward off-.... .
I attach the manual which also shows the wire-colours.
ba-66031-603712-0299-sd.pdf (3,876kb) downloaded 68 time(s).
Markus
Edited by user 30 July 2018 16:48:21(UTC)  | Reason: Not specified
Offline mvd71
#4 Posted : 31 July 2018 00:41:36(UTC)
Yes, the white wire. I thought about that, but operationally it would be a pain in the ass, so I personally would wire to the pick up shoe. I have locos that are wired that way from the factory eg BR24, BR85 and they work really well. Plus it reduces the load on the decoder.
Cheers...
Offline poppa-7
#5 Posted : 01 August 2018 00:45:26(UTC)
poppa-7
Hi Guys
Thanks for the good info. A bit of a misprint on my part the loco is a 3390 so I assume the the same wiring of the smoke applies.
Russell
This page was generated in 0.344 seconds.
