Offline michelvr
#1 Posted : 21 March 2018 03:02:47(UTC)
michelvr
Good Evening,
Lately reading the news on the demise of Fleischmann HO and their beautiful HO Profi Track and the reintroduction of the RocoLine with Track Bed for Roco. I was wondering if Marklin is going to introduce more track pieces to the Marklin/Trix C Track program?
My use of Marklin C track is quite limited and I wish that the program had more useful pieces like double slips, slim three way turnouts and curves bigger than R5. It seems now would be a good time to catch a bigger market share with these missing pieces. What do you think?
Michel
#2 Posted : 21 March 2018 08:22:35(UTC)
Märklin said the slim double slip would be the next new item after the slim curved turnout.
The 24360 came about 10 years after the first announcement, the slim curved turnouts took a few years longer than expected, so have patience with the slim double slip.
#3 Posted : 21 March 2018 11:00:57(UTC)
They have the R9 curve for the slim switches. Lots of people use them to create soft curved "straights", instead of the non-existing flex-track...
Offline michelvr
#4 Posted : 21 March 2018 14:25:49(UTC)
michelvr
BigGrin Patience, Smile patience l'm very lucky because I was blessed with an abundance of patience. Now for time well that I can not control and for me time flies!
Just thinking that l'll be eighty years old in twenty one years made me realize that Marklin might do it in that time frame!
Confused
I figure that Marklin first brought out the C track program in nineteen ninety nine.Cool Well that's about twenty years for the slim curved turnout to be produced so if they produce the slim double slip in the next twenty years I might live to see it! Tongue
The only thing I have to worry about is the Grim Reaper! Scared I hope he does not show up before that time! Flapper
Now if you read all this and smiled, You made my day! ThumpUp
#5 Posted : 21 March 2018 15:24:02(UTC)
The C track programme was meant to take over from the old M track. Considering that there was no provision ever on M track for large radii I think we can be grateful for what we have on C track at present!
#6 Posted : 21 March 2018 17:54:08(UTC)
No, they brought it out earlier than that, it was around 1995. We left NZ in 1997 and it had been out for two or three years then.
#7 Posted : 21 March 2018 18:11:42(UTC)
Marklin C track originated in the Marklin Alpha program around 1991. The tracks were kept on when the Alpha range was dropped and it became the C-track range.
#8 Posted : 21 March 2018 18:29:25(UTC)
The Alpha straight track had a length of 180 mm and the turnouts were R1, not R2. I'm not sure if they kept anything beside the click connectors and maybe the R1 curves.
#9 Posted : 21 March 2018 19:46:45(UTC)
"If it looks like a duck, swims like a duck, and quacks like a duck, then it probably is a duck."
BigGrin
Offline sjbartels
#10 Posted : 22 March 2018 05:01:05(UTC)
sjbartels
So I'll ask, what exactly was the "Alpha Program"? A C track Prelude?
thanks 1 user liked this useful post by sjbartels
#11 Posted : 22 March 2018 07:49:46(UTC)
In a way.
It looks like C track, but came with a different geometry. I think there were only two radii.
Yeah.
But some people bought something that looked like C track on eBay - but it was Alpha track and the lengths were not what they expected.
Alpha track is rare on eBay, but take care if the description is just like "Märklin tracks" without giving the well-known ref. numbers 24xxx.
The new 21xxx tracks also look like C track, but the rails are plastic. The 20xxx C track is normal 24xxx track with different packages.
#12 Posted : 22 March 2018 15:00:04(UTC)
I think there are more differences between C-track and Alpha-track than the ones mentioned already;
The color of the plastic.
The height (code) of the rail used.
Fishplates; Although neither system uses fishplates, the Alpha-track had some plastic-studs under the end of the rail, just about where you would put a fishplate.
#13 Posted : 23 March 2018 11:47:06(UTC)
I believe that probably the Alpha tracks were never intended to replace M tracks when initially designed, but the ease of use and ruggedness of the tracks must have given them the idea to use them with the main Marklin programme. At that point they must have re-thought the geometry and changed other details slightly.
When Alpha disappeared it was a good opportunity to use the tooling from those tracks to launch the full C-track range.
#14 Posted : 23 March 2018 11:52:53(UTC)
Alpha was a range of futuristic trains and fantasy vehicles meant for children. It existed in the 1990s and at its peak boasted two locomotives (a streamlined tender engine available in red or black) and a selection of wagons with fun features such as removable modules for passengers and cargo.
There was also a range of buildings, road vehicles, figures, and dioramas.
This page was generated in 0.516 seconds.
