Offline Thewolf
#1 Posted : 06 March 2018 17:55:40(UTC)
Thewolf
For those who want to know how to do it :
That's exactly what I did.
Thewolf
Project The Richelieu Valley Railway-CS2-Track C- Itrain-Digital
thanks 4 users liked this useful post by Thewolf
Offline Thewolf
#2 Posted : 09 March 2018 18:51:33(UTC)
Thewolf
I solved the problem of the short circuit on the contact rail.
I had the idea of screwing it in to prevent it from moving (my friend Mike had followed me in this direction) and everything is going well.
By the way, I ordered from LDT what I need for better feedback
Thewolf
thanks 3 users liked this useful post by Thewolf
Offline johnpatrickwack
#3 Posted : 12 March 2018 17:59:23(UTC)
johnpatrickwack
I’ve made a lot of contact track lately and enjoyed this video. I wish I’d watched it earlier.
Cheers, John
John P. Wack
Silver Spring, MD
Offline Jabez
#4 Posted : 13 March 2018 16:12:56(UTC)
Jabez
Good how to do it movie.
For me the disadvantage of contact tracks is the requirement to change every axle on your non-Maerklin rolling stock to AC axles. If you run a lot of non-M stock such as Fleischman or Roco which don't already need axle/wheel changing this can be pricey.
Any comments?
#5 Posted : 13 March 2018 16:16:49(UTC)
Any comments?
Conductive silver paint could be the answer.
Maybe two or three layers of paint across the insulation ring (hear-say, no own experience).
In some cases it may be enough to have conductive wheelsets at the last car in the train, but have some non-conductive wheelsets in between.
Offline Thewolf
#6 Posted : 13 March 2018 17:30:31(UTC)
Thewolf
Any comments?
Hi Jabez,
What's the system you're using ?
Thank you for the reply
#7 Posted : 13 March 2018 17:48:13(UTC)
Any comments?
One axle on every bogie and one axle on any two axle wagon should be sufficient, so only half the axles overall, I would suggest. It does mean that a wagon could overhang the end of a block and not be detected as doing so, but careful placement of the block gaps should minimise any danger from this.
#8 Posted : 13 March 2018 19:29:34(UTC)
Any comments?
As others have said, rather than replacing the DC wheelsets with AC wheelsets (so long as the DC ones run fine re flanges/spacing) - applying a conductive paint to bridge the insulator on each axle is the most efficient way to convert the cars I would expect, so long as the S88 sensing system deployed picks up the low resistance produced by the contact paint (it works for DCC / DC systems as they detectd via current draw, but whether the ground-to-ground sensing of S88 would trigger I'd leave to the folks that have done such a thing).
#9 Posted : 14 March 2018 09:36:41(UTC)
I try to change the wheel-sets whenever possible. Because the geometry of the M and K track profile is very different from that of typical 2-rail.
But sometimes it is not needed or practical. In that case I change the wheels of just ONE waggon in the consist (the last one in the rake)
If there is no way of changing ANY of the wheels, I have to insert a waggon with the right wheels into the consist somewhere. (Again; preferrably the last one in the rake)
For a consist of Rivarossi waggons, where the wheels are two half-parts pushed together in a plastic bushing, I simply added a piece of fine curled-up copper-wire between the two axles inside the bushing, which bridged the separation space of the wheelset. A fast, easy and free remedy.
Offline Jabez
#10 Posted : 20 March 2018 19:38:11(UTC)
Jabez
Hi Jabez,
Hi Wolf,
I use C track with circuit-tracks for contact feedback. I have tried reed switches, both Maerklin and Viesmann, but however carefully I lay them they always bump against vehicle wheels or PUs. Maybe there is a trick to reed switch laying that I don't know.
Sorry for the delayed reply. I have been offline for a few days.
Jabez
Offline Jabez
#11 Posted : 20 March 2018 19:39:45(UTC)
Jabez
Thank you all for the helpful comments. That makes things a lot clearer.ThumpUp
Offline fynrfin
#12 Posted : 14 January 2020 23:32:21(UTC)
fynrfin
Thewolf
Thank you, very useful video - is it your experience that one needs to put glue or something isolating between the isolated track and the connected track, for M-track this was important, or is removing the connection piece on the rail enough combined with screwing the rail down?
Steen Jorgensen
Planning a Northern European (DSB and DB) C-track layout with IB control.
This page was generated in 0.607 seconds.
