Offline dhyan
#1 Posted : 07 February 2018 18:55:08(UTC)
dhyan
Purchased this locomotive as an analogue one but on opening it up, found this inside - instead of a reversing unit. I cannot figure out what it is? Can someone help please? Can it be that it is digital decoder but I cannot see any switches to set/change the address.
Many thanks
#2 Posted : 07 February 2018 20:28:01(UTC)
The main components on that board seem to be a bridge rectifier and two power transistors. I would hazard a guess at this being an electronic reversing unit?
I see no sign of a decoder or any other digital component.
Offline dhyan
#3 Posted : 08 February 2018 18:18:26(UTC)
dhyan
Thanks Mr. RayF,
I thought so too but had to inquire because a so called Marklin expert told me that it is a digital decoder.
I run it analogue and it runs beautifully. Here is a picture of its operator.IMG_6402.JPG
Warmest regards
Dhyan.
thanks 2 users liked this useful post by dhyan
Offline Markus Schild
#4 Posted : 08 February 2018 19:36:58(UTC)
Markus Schild
Hi Dhyan,
it is a HERKAT #2655 electronic reversing unit. Works fine unless the battery is empty. The layout was used from the late 1980s, earlier ones are looking slightly different.
Markus
Offline dhyan
#5 Posted : 09 February 2018 10:41:49(UTC)
dhyan
Hi Dhyan,
Markus
Thanks Mr.Marcus,
Very helpful. Hope I do not have to replace the battery ever (I plan to run it in one direction only).
Warmest regards
Dhyan
#6 Posted : 09 February 2018 11:03:28(UTC)
Markus Schild
Hi Dhyan,
When the battery is empty, the loco won't move any more. ROCO and FLEISCHMANN had similar reversing switches in these years. It is not rare that original locos are offered as defective where only the battery must be changed.
Markus
Offline dhyan
#7 Posted : 11 February 2018 23:40:49(UTC)
dhyan
Hi Dhyan,
Markus
Dear Marcus,
Can you give me some idea about the battery as I cannot figure out which component is the battery?
You have been very helpful.
Many thanks and kind regards
Dhyan
#8 Posted : 11 February 2018 23:56:33(UTC)
Markus Schild
Hi Dhyan,
I coloured the contact and the battery.
But if it works don't change it. Just in the case, the loco does not work any more: It's not broken, just the battery.
Markus
Offline dhyan
#9 Posted : 17 February 2018 19:35:45(UTC)
dhyan
Hi Dhyan,
Markus
Dear Marcus,
Another query please. Bought a 3092 steam locomotive and the thing just sits on the tracks. Was told that it is analogue but it is not moving at all. On opening it up, it seems to have a decoder (but not a Marklin one - I think). Can you help me again please? And if it is a decoder, then how to find its address. I have already tried it on my digital setup, but nothing happens there either. See photos. It is a beautiful machine but sadly not running.
Many thanks and warm regards
#10 Posted : 17 February 2018 19:59:16(UTC)
Markus Schild
Hi Dhyan,
Looks like an ESU LokPilot V4.0: http://www.esu.eu/produkte/lokpilot/lokpilot-v40/ There is also a link for the manual. I cannot determine whether the decoder shown is the full version, or a version only understanding DCC.
The easiest would be to reset it following the manual.
Markus
Offline dhyan
#11 Posted : 17 February 2018 21:28:32(UTC)
dhyan
Hi Dhyan,
Markus
Thanks Dear Marcus. Will work on it tomorrow and will let you know if I am successful.
Kindest regards
Dhyan
Offline dhyan
#12 Posted : 20 February 2018 17:51:48(UTC)
dhyan
Originally Posted by: dhyan Go to Quoted Post
Hi Dhyan,
Markus
Kindest regards
Dhyan
Tried everything but it does not run. My mobile station recognizes it as a DCC one with address 0 but it does respond to any of the inputs from the mobile station. I have changed the address, reset it, reset the mobile station etc. - still dead.
Any tips would be helpful
Kind regards
Dhyan
Offline franciscohg
#13 Posted : 20 February 2018 20:02:09(UTC)
franciscohg
Chile
Hi, did you tried in analog? With a white transformer....
Offline dhyan
#14 Posted : 20 February 2018 21:17:50(UTC)
dhyan
Yes, I did. But still no movement. Such a nice steam loc but dead.
#15 Posted : 21 February 2018 09:50:35(UTC)
Do you know when it last ran? Are the wheels free? Just ruling out it being seized from dried lubricant.
It does rather sound like the decoder is kaput! But wait a little longer in case someone else does have the same decider and might have some ideas.
Offline dhyan
#16 Posted : 21 February 2018 10:48:39(UTC)
dhyan
No idea when it last ran. Bought it on eBay from a recognized dealer as a running loc, but it is dead. Wheels and motor are turning over. It is not frozen.
Offline franciscohg
#17 Posted : 21 February 2018 18:03:34(UTC)
franciscohg
Chile
last call, brushes?
If not, it certainly sounds as a dead decoder. Good moment to upgrade to full sound!
#18 Posted : 21 February 2018 18:43:35(UTC)
Hi Dhyan,
Markus
Kindest regards
Dhyan
Kind regards
Dhyan
Interesting that an MS seems to detect it, wonder if a CS might give more options?
Makes me think.... "restore factory defaults", if someone knows how. Got a friend or dealer with a CS?
Offline franciscohg
#19 Posted : 21 February 2018 20:38:03(UTC)
franciscohg
Chile
That may help, but if is not working on analog is a bad sympton, unless the previous owner disabled analog mode.....
Offline dhyan
#20 Posted : 22 February 2018 00:34:51(UTC)
dhyan
last call, brushes?
Brushes are good. I am sending it back to the seller. Thanks everyone for your help.
Kind regards and have fun with your hobby.
Dhyan
Offline jerdenberg
#21 Posted : 24 February 2018 13:33:03(UTC)
jerdenberg
The total "deadness" suggests there could also be a very trivial reason, i.e. the track voltage not reaching the decoder; that is not very likely, but only a check can establish that. I could imagine the connection between the slider and the decoder was feeble, but functional, on dispatch from the seller, and broke down during transport.
Jeroen
thanks 1 user liked this useful post by jerdenberg
Offline dhyan
#22 Posted : 24 February 2018 17:24:04(UTC)
dhyan
Jeroen
Thanks for your guidance. I have already returned it to the seller. Let's hope he can fix it.
Kind regards
Dhyan
This page was generated in 0.737 seconds.
