Offline Abdul
#1 Posted : 02 September 2013 08:37:21(UTC)
Abdul
Bahrain
I have a train set 2875 Freight Train Set with Large M Track Layout, and Transformer 6631 30 VA and Control Boxes 7072.
I need to connect the M Track 5128, 5202, 5207 to the control box and then to the Transformer.
Can any one send me the Manual Instruction or link, as I am not expert in wiring connection.
Appreciate your help.
#2 Posted : 02 September 2013 09:05:50(UTC)
Turnouts have two blue wires and a yellow wire.
The blue wires should have a green and a red plug - they connect to the control boxes. If the plugs are not connected, it's trial and error (50 % chance).
The control box (connector on the short sides) must be connected to the brown output of the transformer.
The yellow wire from the turnouts goes to the yellow connector of the transformer.
Green on the control box sets turnouts straight, red sets them round (by convention). Swap red and green plugs if it works the other way.
Offline Abdul
#3 Posted : 02 September 2013 13:45:56(UTC)
Abdul
Bahrain
I am new to the forum
Moved this post from Gemeral MRR to here because Abdul already had a thread started here with the same subject.
(kweekalot)
Edited by moderator 03 September 2013 14:58:20(UTC)  | Reason: Not specified
#4 Posted : 02 September 2013 13:57:26(UTC)
One thread is enough:
https://www.marklin-user...nsformer.aspx#post414878
Thanks Tom, the threads are now merged.
Edited by moderator 03 September 2013 15:00:09(UTC)  | Reason: Edit by moderator
Offline sjlauritsen
#5 Posted : 02 September 2013 14:02:19(UTC)
sjlauritsen
True,
I will always recommend following the Märklin color codes when setting up the layout. It is a very good help, when something goes wrong and easy to debug.
Even though I run 2-rail I still use the Märklin color codes. Mostly because many other manufacturers use them or have their own color codes inspired by Märklin.
Søren from Denmark
thanks 1 user liked this useful post by sjlauritsen
Offline Abdul
#6 Posted : 03 September 2013 07:40:53(UTC)
Abdul
Bahrain
Its work thanks
Offline pawat
#7 Posted : 02 May 2017 13:56:56(UTC)
pawat
Thailand
thanks ,I have a same problem and i found this answer.
Offline Lil_Mury
#8 Posted : 16 November 2017 17:40:07(UTC)
Lil_Mury
Romania
Hello all. Sorry I`m new in the forum and new in the Marklin World. Recently I have bought an used k track and a locomotive with some wagons. Is it possible to connect Marklin 6631 Transformer to Marklin 2297 Uncoupler? Or what do I need to can start the train, beside the Transformer (6631).
thank you very much
#9 Posted : 16 November 2017 20:21:29(UTC)
This booklet takes you through the aspects of wiring a Marklin layout, and should answer all of your questions.
https://lnx.3rotaie.it/wp/?wpfb_dl=901
Offline nzrabbitty
#10 Posted : 09 January 2018 14:20:22(UTC)
nzrabbitty
Thanks for the wiring guide for analogue Layout .
Just about to start working with M track and an analogue layout
And I had Forgotten What I already knew
this is a good quick memory jogger
I Have found A Cheap and safe way to Have an Exciting Life
Get Married And Give your Wife A Hard Time
You Know Your Going To Get A Thick Ear
BUT you never know When
Chris
Guest (4)
This page was generated in 0.895 seconds.
