Offline jonas_sthlm
#1 Posted : 17 May 2017 08:03:59(UTC)
jonas_sthlm
Yesterday's job, upgrade of engines and a sound decoder Cool
thanks 5 users liked this useful post by jonas_sthlm
Offline 3rail4life
#2 Posted : 18 May 2017 06:22:27(UTC)
3rail4life
Nice work on on the F7's ThumpUp ThumpUp , for the multi units I like to use the factory speaker E169084 for a bit more volume...
Plenty of space in those B units.
Gordon
thanks 5 users liked this useful post by 3rail4life
#3 Posted : 18 May 2017 07:51:46(UTC)
Very nice. Looks like a factory job. I like the strict observance of Mârklin official wiring color code.
Doesn't look like you used LEDs . Quite easy to do here as you can simply plug white 3 mm LED in the socket and add a 1 k 1/4 W resistor in series
Also if you used an ESU decoder, there is a setting for Mars lights. Very realistic too
And a super-sound set up that is very close to what you can hear on the real thing like running on idle, dynamic brakes, "run 8" , etc.
#4 Posted : 19 May 2017 17:56:30(UTC)
If you use an ESU V4 decoder you can also get the Full Throttle facility which allows the driver to separate the motor sound and loco speed in a prototypical way for US locos. There are also schemes with two motors loaded into one decoder if you want the multiple lotor sound without installing multiple decoders. Not sure if they have done this for an F7, but there is certainly a sound scheme using FT that will suit an F7. I have a 3649 (digital version of same loco) that I want to put one of these in.
This page was generated in 0.239 seconds.
