Offline CanadianKid
#1 Posted : 29 April 2017 07:59:19(UTC)
CanadianKid
Today I attempted to finish the installation of a Seuthe no 24 smoke generator into my Bavarian G 5/5. I ran into a rather large issue as the smoke generator would not go far enough into the stack so the generator would push too far down on the contact tongue, resulting in poor amounts of smoke generated. I proceeded to file the interior of the smoke stack a little bit, but from what I could tell, that is not the issue. I believe that the smoke generator will not go far enough into the stack because the part where the smoke generator increases in diameter, (the bottom bit), is already touching the top of the inside of the boiler.
Anyways, I'm not to sure if that was coherent entirely, so I can always post photos in the morning if this makes little to no sense.
Any ideas on how to rectify this issue? (Is it possible that this is the wrong smoke generator?)
Thanks in Advance,
Matthew
Edited by user 29 April 2017 19:45:05(UTC)  | Reason: Status of Post changed to Solved
#2 Posted : 29 April 2017 08:50:29(UTC)
Usually you need Seuthe No. 20 for digital Märklin locos. Using No. 24 instead of Seuthe No. 20 results in less smoke being generated.
Offline CanadianKid
#3 Posted : 29 April 2017 19:44:34(UTC)
CanadianKid
Yeah thanks,
My dealer gave me the wrong one I guess. I'm new to this installation process; this is only my second time doing it.
Thanks for the Help,
Matthew
Offline Crazy Harry
#4 Posted : 29 April 2017 22:39:58(UTC)
Crazy Harry
According to the Seuthe website the 20 and 24 smoke generators have the same physical dimensions. The only difference is the operating voltage:
Model 20 is rated for 10 to 16V AC or DC
Model 24 is rated for 16 to 22V AC or DC
The Marklin website calls for smoke generator 72270 which translates to Seuthe 20 according to the service section (Seuthe Service Info) of Seuthe's site. Seuthe also states that model 20 is the correct smoke generator for Marklin digital locomotives as H0 has mentioned above. The voltage difference probably explains your weaker smoke generation.
Hope this helps,
Harold.
thanks 3 users liked this useful post by Crazy Harry
This page was generated in 0.375 seconds.
