Online Drongo
#1 Posted : 22 April 2017 13:27:01(UTC)
Drongo
Can someone explain to me how I can change the brightness of the lights on a Signal 74391.
I've connected the signal to a m84 (60841) and the m84 manual says that the c38 changes the brightness of the LED's. I have access to a CS2 or an ESU EcoS 50200
Greg
#2 Posted : 22 April 2017 14:13:00(UTC)
Hi, Greg,
Connect the m84 to the programming track of the ECoS, go to the DCC programming screen on the ECoS and change CV 38.
With the CS2 it is more complicated as you have to create a dummy loco to program the decoder.
Online Drongo
#3 Posted : 22 April 2017 14:24:00(UTC)
Drongo
Thanks Tom, I'll give it a go tomorrow morning.
Much appreciated.
Greg
#4 Posted : 22 April 2017 23:41:21(UTC)
CV editing on a CS2 via the Accessory Setting page has been available for a couple of releases
(initially, when the m83/m84 came out, you did need to use the dummy loco method)
This includes POM(sic) capability for both DCC and MM
#5 Posted : 22 April 2017 23:43:10(UTC)
If you have the newer hardware versions of the m84, with SW8 (which just sets the lights on full with no reference to the CV) you may need to set this off.
Online Drongo
#6 Posted : 23 April 2017 08:57:54(UTC)
Drongo
Thanks for the advice fellas - all is working well. BigGrin BigGrin BigGrin
This page was generated in 0.281 seconds.
