Offline twmarklinfan
#1 Posted : 28 February 2017 12:51:01(UTC)
twmarklinfan
Hi when I bought the loco I also purchased the 72270 smoke unit for it. This morning I am trying to fit it. Usually I find the units are a snug fit but are quite easy to install. This one is different, there is a huge resistance and I am afraid to damage either the loco or the smoke unit.
Has anyone successfully installed the smoke unit and how did you do it?
Thanks in advance
Offline AmalfiCoast
#2 Posted : 28 February 2017 15:43:46(UTC)
AmalfiCoast
Hello Adrian,
I installed that smoke unit in my BR41 and I too thought I was going to break something forcing it in the stack. I've read that you can lightly sand around the inside of the stack but decided not to do that. I simply applied a bit more force and it slid right in. Good luck.
David
Offline ktsolias
#3 Posted : 28 February 2017 18:35:44(UTC)
ktsolias
You can't broke nothing inside the Loco
Push more all around the smoke generator pipe.
The contact must be firm
Costas
#4 Posted : 28 February 2017 20:57:59(UTC)
twmarklinfan
Costas
Thanks Costis
Will let you know how I get on
This page was generated in 0.229 seconds.
