Offline MaerklinLife
#1 Posted : 28 November 2016 06:28:34(UTC)
MaerklinLife
Hello all
I have a peculiar problem with my Mobile Station 2.
Here is some set-up info:
- I use mainly mfx with a few DCC chips as well. I have no MM locomotives.
- I use the Mobile Station 2 connected to the Central Station 2 using the terminal.
- The Mobile Station 2 is at the latest software available to the CS2 (SW 2.5).
- MS2 HW: 2.0.
- I have several Mobile Station 2's and the problem occurs on all of them.
The problem is:
Whenever I change the locomotive the function buttons switches position to what seems random positions. They also do not work as expected. Repeatedly changing the locomotive back and forth on the Mobile Station eventually puts the function buttons back in their original positions and working again. This is insanely annoying.
It happens when turning the knob, and when inserting a loco card. Reproduction is very easy, since it happens almost all the time.
Note: It does not seem to happen with the Mobile Station 2 connected to the railbox and working on its own.
I have not been able to spot any pattern as to when it happens. Have any of you?
Do you know about a solution (I suspect this to be a software issue, so a solution might not be available) or a work around?
This page was generated in 0.334 seconds.
