Offline Laurna
#1 Posted : 12 October 2016 03:21:05(UTC)
Laurna
Argentina
Location: Ciudad Autonoma de Buenos Aires, Buenos Aires
Hi guys, (BTW the forum is great!!!)
I have a DHG from de 29182 start set, and the locomotive has had problems tu run in a smooth way as it did a couple of years ago.
I've cleaned my C tracks, wheels and change rubber tires, but it doesn't work. Is there any part of the Forum where I can find info for motor maintenance???
Thanks!!
Offline Thewolf
#2 Posted : 12 October 2016 15:12:59(UTC)
Thewolf
Hi LaurnaCool
Did you oil the wheel axles ? And clean the axles ?
Thewolf
Project The Richelieu Valley Railway-CS2-Track C- Itrain-Digital
Offline Harryv40
#3 Posted : 13 October 2016 08:41:02(UTC)
Harryv40
Hi Laurna
Could I suggest you delete and reinstall the loco from your digital system, this sometimes helps running. Also clean the pick up just in case and make sure the pick up move up and down freely.
I had a loco with poor running and found the pick up had moved and was not in place correctly.
Harry
Offline Laurna
#4 Posted : 15 October 2016 00:36:49(UTC)
Laurna
Argentina
Thanks!!!!!!!! I'll tale all the advices, thanks a lot.
This page was generated in 0.594 seconds.
