Offline DV
#1 Posted : 02 September 2016 06:06:55(UTC)
DV
If this is in the wrong topic, can moderators please move......sorryBlushing Blushing Blushing Blushing Blushing Blushing Blushing
This might be a stupid question to the electronics experts out there, but............................................
Just purchased LED strip lighting and was advised that I required a 12 volt (Australian) power source to light the strips. Me not thinking, asked if a model train transformer would be sufficient and the answer was yes.
Unfortunately the salesperson couldn't read my mind that I was thinking of a Märklin transformer....doh!.
So, can a Märklin transformer (the accessories part) be used to power LED strip lights?
Or will they burn out due to AC being supplied to them?
Many thanksThumpUp
Dusan V
#2 Posted : 02 September 2016 07:48:14(UTC)
The question should be in the crystal ball forum.
The question is good, but cannot be answered without additional information.
Depending on the diodes on the LED board it may work safely with AC.
If it was made for 12 V DC then 16 V AC may still be too much.
Yes, AC could be a problem.
Yes, 16 V AC could be a problem even if 12 V AC were OK.
DV
Offline Johnvr
#3 Posted : 02 September 2016 07:53:23(UTC)
Johnvr
My recommendation is that you do the following :
You purchase a RECTIFIER and a 12v REGULATOR.
The RECTIFIER converts AC into DC (two wires AC coming in, two wires DC going out),
and the 12v REGULATOR will regulate the voltage to 12v.
For added reliability, get a small piece of circuit board and get 2x socket connectors for in and out and solder the parts on the board.
I can give you a circuit diagram if you require.
Regards,BigGrin
DV
#4 Posted : 02 September 2016 07:58:35(UTC)
That's a safe way.
Depending on the specs of the LED board there may be cheaper options.
DV
Offline DV
#5 Posted : 02 September 2016 08:10:59(UTC)
DV
It states on the package 12V 6000K light 720LM P/M, is that of any help?
It also states that the LED strips, must not exceed 5 metres, when used in a DCseries circuit...is that of any help as well.
Dusan V
#6 Posted : 02 September 2016 08:15:01(UTC)
Are the strips cheap? Try it on a short strip and see what happens. If you smell burning switch it off! Obviously you need to take precautions to prevent injury to you and damage to your work surface.
DV
Offline DV
#7 Posted : 02 September 2016 08:23:13(UTC)
DV
Regards,BigGrin
Thanks John,
for a newbie in this field that's a lot of info, and it'll take me a while to digestBigGrin BigGrin, as I'm looking for a simple solution (if there is such a thingBigGrin ) .
What about if I used an old computer drive transformer (that is still in operating order of course), cut off the plastic plug, split the wires and join the LED's to the split wires...........or is that too simple and could cause big problems.
Dusan V
Offline DV
#8 Posted : 02 September 2016 08:25:46(UTC)
DV
Ray, that was my initial idea, but I thought that maybe there might be an answer where I can bypass that processBlushing .
Doesn't look like it, so I'll have to have an experimentBigGrin ThumpUp
Dusan V
#9 Posted : 02 September 2016 08:28:34(UTC)
Make sure that you do the experiment away from open cans of fuel and Samsung washing machines! LOL
Offline DV
#10 Posted : 02 September 2016 08:39:15(UTC)
DV
Funny you should say that, especially about two weeks ago some guy was transferring LPG from canisters to his truck in the carport, went had a cup of tea while that was happening, only to have first that LPG tank blowing up, and when he ran from the house, the rest of the tanks went up as well.
When I heard the bang I thought the missus had fallen down the staircaseBigGrin BigGrin BigGrin BigGrin
You might have seen this on your tv or internet Explosion
Dusan V
thanks 1 user liked this useful post by DV
#11 Posted : 02 September 2016 08:58:05(UTC)
Not really.
Are the connectors for power marked with "+" and "-"? If so, I would assume it is DC only.
A switching mode power supply for 12 V DC would be a simple solution.
PC power supplies are not safe for children - grown-ups have to decide whether they can take that risk. A short circuit on the layout may lead to unexpected results. Some use extra fuses to protect the power supply.
DV
#12 Posted : 02 September 2016 22:58:14(UTC)
Ouch, not the sort of excitement you want around home ...
OhMyGod OhMyGod OhMyGod OhMyGod OhMyGod OhMyGod OhMyGod OhMyGod
This page was generated in 0.478 seconds.
