Offline davidtfrs
#1 Posted : 31 August 2016 19:20:40(UTC)
davidtfrs
I have two old Märklin 3000 (DB 89 006) analog.
The newer of the two started to go slower a month back or so, now it doesn't run at all without giving it a push.
I've opened it up and cleaned it out with a cotton swab and put some new oil on the oiling spots, that didn't help.
So I talked to my local dealer and got a pair of new motor brushes (E601460), didn't help either.
I can see that small sparks appear inside by the brushes if I run it with the loco body off, also the brushes looks a bit burned.
Could it be the 3 pole anchor that is broken? I cant really tell from looking at it. Attaching images.
Offline Hoffmann
#2 Posted : 31 August 2016 19:55:04(UTC)
Hoffmann
One Segment of your Rotor ( anker ) is broken. You are running on 2 Zylinders instead of 3. You need a new Rotor ( anker ).
Martin
marklin-eh
Offline davidtfrs
#3 Posted : 31 August 2016 19:59:49(UTC)
davidtfrs
Thank you Martin for your reply!
Could you tell that from the picture or is it a typical behaviour?
I'll order a new anchor in that case.
Thanks again!
Offline Hoffmann
#4 Posted : 31 August 2016 20:13:33(UTC)
Hoffmann
Looking at your Picture of the Rotor it seems that a Wire is broken on the top segment ( I could be wrong ).
Regards Martin
marklin-eh
#5 Posted : 31 August 2016 20:43:25(UTC)
Regards Martin
I thought so too!
Offline Dave Banks
#6 Posted : 31 August 2016 21:10:48(UTC)
Dave Banks
Hi, I concur, new armature required. Old one looks well worn & seems to have a broken wire. #231440
Dave...
http://www.ebay.de/itm/Marklin-...%3D6%26sd%3D131854227947
D.A.Banks
#7 Posted : 31 August 2016 21:13:06(UTC)
Martin
Absolutely correct.
I have hundreds of these in my spares inventory.
If you want to I can send a couple, just for mailing cost.
Good call!
#8 Posted : 01 September 2016 05:05:25(UTC)
on the other hand if you can unwind the broken wire without breaking it again you could solder it to the missing spot and you could save yourself some money but as Jacques said he has got plenty (so do I)
Offline Moritz-BR365
#9 Posted : 01 September 2016 07:42:23(UTC)
Moritz-BR365
I can't see, that there is a broke wire. But, if the loco starts to become slower and slower, this is in most cases because of abrasion from the brushes filled into the collector gaps.
I use a small needle to take the abrasion away and clean the collector carefully. The brushes should be cleaned as well. The same for the motor shield.
Be very spare with oil on the motor shield!!! When the oil reaches the collector and brushes, the gaps will fill again within a few hours of driving! Better then oil is, to mount a ball bearing into the motor shield. Then You will never have to use oil for the anchor!
Moritz
#10 Posted : 01 September 2016 11:40:32(UTC)
Moritz, for absolute better performance have a close look at your motor shield and tell me if you find any abnormalities. a.) always check the spring tension (in right position, b.) when drilling a hole for the ball bearing always make sure its in the centre and c.) only use one diode (between the spring tensions = as per above picture) for the loco (when using ESU decoders., d.) most modelers don't realize the brushes are most the time not in a 90° angle and this either makes the loco more noisy and slower and therefore can also hinder the loco to perform properly at slow speed.
Offline davidtfrs
#11 Posted : 01 September 2016 19:03:41(UTC)
davidtfrs
Martin
Absolutely correct.
Good call!
You got a spare rotor? That would be great!
Offline davidtfrs
#12 Posted : 01 September 2016 19:20:47(UTC)
davidtfrs
Moritz
Thanks for the reply, do you mean the gaps in the surface where the brushes interact with the rotor?
#13 Posted : 01 September 2016 22:37:29(UTC)
Moritz-BR365
Yes, exactly! I have a BR 50 which run slower and slower, finally it stops. I cleaned the gaps, removed much abrasion, cleaned the brushes and it was like a new loco!
This page was generated in 0.588 seconds.
