#1 Posted : 24 August 2016 15:05:29(UTC)
today I've handed over another 6 locos which I had converted to digital with ESU sound decoders.
3 Steam locos, BR, 18, BR 86, BR 24 (3003), 3 diesel locos, BR 188, Rh 2016, BR 361.
BR 18: gearlight, firebox, smoke generator, led's front & rear. ball bearings
BR 86: gearlight, firebox, 2 x telex couplings, led's front & rear. ball beatings
BR 24: gearlight, firebox, led's front & rear. ball bearings
BR 188: 1 x telexcoupling, marker lights, ball bearings
ÖBB Rh 2016: 2 x Telex couplings, high beam, marker lights, led's front & rear.
BR 361: led's front & rear, marker lights front & rear, programmed existing telex couplings, ball bearings
my own railcar 3028, 3428 are being updated again with more knowledgeable ideas, e.g. smd resistors, smd led's and a more comprehensive light change, Roco electr. couplings which include coupling shafts.
my ÖBB Roco crocodile (Rh 1089) is also transformed with new ideas., Led's front & rear, marker lights, ESU sound decoder and a small loudspeaker. had to do some filing around the previous light chamber to be able to fit the loudspeaker into the spot. so I'm quite exited about the outcome. this loco never came out in AC but the advantage is running it via the pantographs this solves this problem, I still need a slider to activate the reflective couplers so a slider will be attached onto the first coach or the first freight car.
Offline Moritz-BR365
#2 Posted : 24 August 2016 15:37:57(UTC)
Moritz-BR365
Pictures? Video?
#3 Posted : 24 August 2016 17:23:40(UTC)
Originally Posted by: Moritz-BR365 Go to Quoted Post
Pictures? Video?
unfortunately not, they have gone now but the rail car will become public., there is one for the BR 188
Offline dominator
#4 Posted : 25 August 2016 03:24:48(UTC)
dominator
Hi John, can you give detailed costings on that work. Dereck
#5 Posted : 25 August 2016 04:08:13(UTC)
Dereck send PM
This page was generated in 0.270 seconds.
