#1 Posted : 14 August 2016 10:47:00(UTC)
Hi, Ho, just a question on the 6021, I know you can connect the 6021 to the ECoS but can you use the key boards on the left hand side or memory ? or can you only add controllers onto the right hand side of the 6021. ?
#2 Posted : 14 August 2016 12:32:07(UTC)
You can use keyboards, but I'm not sure why you'd want to use memory units when that function is built into the Ecos.
Since the Ecos 'sniffs' the track output of the 6021, I would think you could use any device that plugs into the 6021.
#3 Posted : 14 August 2016 13:46:06(UTC)
its just a thought., a friend of mine would like to upgrade his system from the 6021 but he wants to know what will happen with all his keyboards 6083 decoders, so in a nutshell, he most probably uses the ECoS for all his locos and all the other bits for his turnouts and signals + the 6021.
I'm going there next week and I'm having a look at his layout and see what I can recommend.
This page was generated in 0.273 seconds.
