Offline Gunter
#1 Posted : 13 August 2016 15:54:51(UTC)
Gunter
Greeting everyone,
First time post here! Please bare with me, and my ignorance, but after nearly 30 years after getting my first marklin set, I have dusted off my old track, purchased a digital controller (6001 and 6021), and upgraded to digital! Its been a blast.
However, I am starting to be limited by my ignorance of all things electrical (and somewhat mechanical). So as I finalize my layout, and start to lay the track in earnest, I have a few questions.
A little about the layout. Its all M track, about 60-65’ of track, 6 switches (5202 & 5137), one 5207, 6021 controller and 6001 transformer, one set of lead wires to the track. I have extensive lighting that I am wiring on an old separate transformer (a few spare 6627’s).
I plan on adding another 60-70 feet of track, another 5 or 6 switches (likely 5202 and 5137), and also some track signal and incorporating some of the control track sections.
So my questions are as follows, and I am sure that I will have many more!
1) Do I need to power my 5202/5137 switches from the 6021, or can I use an old spare 6627 to power the switches (independently wired) if the 6021 is powering the track? If I can use the 6627, does it need to be tied in to the system in any way?
2) Can I use something like the keyboard 6040 to control the turnouts and track signals?
3) If I am wiring pieces into the track, like a 7191 end block, do they also need to use the 6021, or can they also be fed by an independent transformer, like in #1 above?
4) Some of my less expensive older delta trains, appear to have their power drop on various parts of the track. I imagine that I need to either boost the power, or put in more feeder lines (and I am always scared when I read about isolating track because I have no idea what this is), or…well. I don’t really know. This is probably my biggest area where I need advice.
5) Is there a way to access the additional features of mfx trains, beyond moving to the control stations? I have a 6 year old, and I want to try to keep it more bottom push simple for him (and me).
6) Do solenoids work with digital? Why did I need to remove the solenoid from my feeder track before hooking up the 6021…Do you see the level of my confusion? Lol.
7) Based on what I am planning above, any advice, tips, are greatly appreciated!
I know that there are lots of random questions above, but I have been struggling with this for months, so any help is greatly appreciated.
Thank you all in advance, and looking forward to be part of the forum!
Gunter
Offline Tex
#2 Posted : 13 August 2016 16:57:12(UTC)
Tex
Gunter
Welcome to the forum. I have two comments.
First with regard to questions 1 and 2. I attempted to control M track switches ( turnouts ) with my 6021 using decoders with poor results. The looser turnouts worked sometimes and the tighter ones almost never , with the double slip switches being the worst. I changed to push buttons and they worked every time. I prefer the Viessmann push buttons to Marklin .
Second be aware that a poorly planed layout will take three times as long to complete as you expected but if you take great care in your planning it will only take twice as long ! In other words , get going.
Best of luck, Tex
Offline Gunter
#3 Posted : 13 August 2016 17:23:21(UTC)
Gunter
, Tex
Thank you so much Tex. I appreciate the help. I was thinking about just using the push buttons, as I have some of the older blue marklin units. Would you happen to know if I need to power the turnouts through the 6021 that I am using to power the track, or could I use a completely independent source, like the old 6627 transformers (and hence not draw too much from the 6021 running the trains). But this ties in again I suppose with my questions regarding total track power...
#4 Posted : 13 August 2016 17:41:29(UTC)
Hi, Gunter,
With older mfx decoders you can get 9 functions using 2 MM addresses, with newer decoders you can get 15 (Märklin) or 17 (ESU) functions using 4 MM addresses.
See also:
http://th-soft.com/eblog...unctions-with-mfx-locos/
Offline Tex
#5 Posted : 13 August 2016 19:17:59(UTC)
Tex
, Tex
I have a fairly large layout and power my turnouts from a separate transformer and, also, use a booster for track current.
Before you get too far along you might want to look at going for C track especially if you plan to use some of the newer products being offered. For example, I was told by a dealer that the new ESU engines should not be used with M track but would work with C track. The C track system will give you tighter fitting connections as well as more realistic wider turns. I think if I were to be starting over I would use C track despite the higher cost. M track will work but requires care to avoid wide gaps ( don't ask me how I know )
Tex
thanks 1 user liked this useful post by Tex
Offline cmobrienjr
#6 Posted : 09 February 2017 02:40:31(UTC)
cmobrienjr
Good
Offline sgtb
#7 Posted : 10 February 2017 03:15:18(UTC)
sgtb
If your going to use your old m track, don't forget removing the suppressor from the power track going from analog to digital.
Bob
Offline baggio
#8 Posted : 10 February 2017 19:26:58(UTC)
baggio
Welcome to the forum, Gutnter. BigGrin
I can see you have a HUGE layout in mind; sounds great. Please show us some pictures of how you come along.
Bob
Bob: could explain what this means? Thanks.
Silvano
This page was generated in 0.910 seconds.
