#1 Posted : 27 July 2016 07:10:06(UTC)
this message is for all members and Stefan Unholz specifically. For over 72 hours, I have been unable to access the Swiss Hag Forum website.
I get the following error message:
Fatal error: Invalid SQL: SELECT COUNT(*) AS amount FROM wcf1_user LIMIT 1
You get more information about the problem in our knowledge base: http://www.woltlab.com/help/?code=1146
Information:
error message: Invalid SQL: SELECT COUNT(*) AS amount FROM wcf1_user LIMIT 1
error code: 1146
sql type: MySQLDatabase
sql error: Table 'usr_web55_2.wcf1_user' doesn't exist
sql error number: 1146
sql version:
file: /home/www/web55/html/hag/forum/wbb/wcf/lib/system/database/MySQLDatabase.class.php (116)
php version: 5.2.17
wcf version: 1.0.10 (Horizon)
date: Wed, 27 Jul 2016 05:08:45 +0000
request: /
referer:
Stacktrace:
#0 /home/www/web55/html/hag/forum/wbb/wcf/lib/system/database/Database.class.php(116): MySQLDatabase->sendQuery('SELECT ?COUNT(*...', 1, 0)
#1 /home/www/web55/html/hag/forum/wbb/lib/system/cache/CacheBuilderStat.class.php(23): Database->getFirstRow('SELECT ?COUNT(*...')
#2 /home/www/web55/html/hag/forum/wbb/wcf/lib/system/cache/CacheHandler.class.php(252): CacheBuilderStat->getData(Array)
#3 /home/www/web55/html/hag/forum/wbb/wcf/lib/system/cache/CacheHandler.class.php(195): CacheHandler->rebuild(Array, true)
#4 /home/www/web55/html/hag/forum/wbb/wcf/lib/system/cache/CacheHandler.class.php(155): CacheHandler->load(Array)
#5 /home/www/web55/html/hag/forum/wbb/lib/page/IndexPage.class.php(44): CacheHandler->get('stat')
#6 /home/www/web55/html/hag/forum/wbb/lib/page/IndexPage.class.php(26): IndexPage->renderStats()
#7 /home/www/web55/html/hag/forum/wbb/wcf/lib/page/AbstractPage.class.php(77): IndexPage->assignVariables()
#8 /home/www/web55/html/hag/forum/wbb/wcf/lib/page/AbstractPage.class.php(36): AbstractPage->show()
#9 /home/www/web55/html/hag/forum/wbb/wcf/lib/util/RequestHandler.class.php(63): AbstractPage->__construct()
#10 /home/www/web55/html/hag/forum/wbb/wcf/lib/util/RequestHandler.class.php(100): RequestHandler->__construct('Index', Array, 'page')
#11 /home/www/web55/html/hag/forum/wbb/index.php(9): RequestHandler::handle(Array)
#12 {main}
Has anybody else had any trouble accessing the site or is there something wrong with my settings that may be causing this issue?
#2 Posted : 27 July 2016 07:19:11(UTC)
If it is at http://forum.hag.ch/ then it worked fine for me..
Have you tried Ctrl-F5 to clear your cache?
#3 Posted : 27 July 2016 07:37:19(UTC)
The question is about the older HAG forum:
http://www.forum.hag-info.ch/index.php?page=Index
Stefan, one of the administrators there, is a contributor here and may be able to provide some Insider information.
It seems the provider has a problem with the SQL databases and I read that several Swiss sites were affected.
Offline Unholz
#4 Posted : 27 July 2016 07:52:51(UTC)
Unholz
There is indeed a problem caused by the provider, and additionally the webmaster is enjoying his summer holidays and is unable to perform the necessary actions, so I can't say when the forum will be running again.
However, life outside the Internet forums does exist...Flapper BigGrin
#5 Posted : 27 July 2016 08:29:32(UTC)
...additionally the webmaster is enjoying his summer holidays...
Shock horror gasp! Scared Real webmasters don't take holidays - hey Juhan? Wink
Offline Unholz
#6 Posted : 27 July 2016 20:31:29(UTC)
Unholz
The HAG forum is running again.
This page was generated in 0.328 seconds.
