Offline PMPeter
#1 Posted : 29 June 2016 00:41:47(UTC)
PMPeter
Every once in awhile you make an eBay purchase and it ends up being a damaged item. I have bought numerous K83 decoders over the last 3 years and up until today all have worked perfectly. Today I installed one of the newer plug style K83s that I obtained sometime in the last 6 months and the minute I turned the power on, the CS2 went into an overload shutdown. Disconnecting the power from the K83 got rid of the overload.
No magical smoke, no burnt smell, just a dead short. So I opened it up and found a burnt component as can be seen in the attached photos.
Circuit board
K83
Burnt component lower right
Burnt component
Since I know we have a number of electronics experts on this forum, does anyone know what this component is? It has 2 bands on it, but due to the burning I cannot tell what colour they were. It is not a capacitor nor resistor since they are all identified on the circuit board.
Since I do not know who the seller was for this unit, and due to the timeframe involved I no longer can go after the seller and can only try and repair it or throw it out.
#2 Posted : 29 June 2016 08:04:55(UTC)
Hi, Peter!
With high certainty it is a diode, connecting "red" with the centre socket of each turnout output.
I cannot estimate the rating of the diode: 1 A, 2 A, 5 A.
I think I'd try 1 A or 2 A if it was mine - better to burn the diode and not the output transistors in case of trouble.
Maybe someone can identify the rating of the original diode.
BTW: When you open the connection between "DATEN" and "+UB" then you should be able to operate the turnouts with external power (AC or DC) instead of track power.
#3 Posted : 29 June 2016 10:44:07(UTC)
It´s 2 amp.
Märklins k83 do accept tolerance maximum output at 2 amps load.
Offline PMPeter
#4 Posted : 29 June 2016 16:02:23(UTC)
PMPeter
Thanks to both of you.
Does it matter what type of 2A diode I get as long as the voltage rating is greater than 25V and it is roughly the same physical size?
I'm still not sure what the second band on the burned out one indicates since most of the ones I can find online have a single band.
#5 Posted : 30 June 2016 01:01:54(UTC)
You do have to get the right kind of diode, as there are several types of diodes in the world of electronics designed for differing applications. (I cannot at present see the images as my employer blocks access to dropbox).
There's always a line/ring at one end (black or light colored) that is the CATHODE side of the diode - that needs to be installed the right way around + the right rating and type needs to be used.
Some diodes are placed to bleed off high spike voltages (at relays and switches) and others to ensure the direction of flow of current (eg in rectifiers), etc. and the type and rating of the diode matters for the correct function of the electronic circuit.
#6 Posted : 30 June 2016 02:17:29(UTC)
Original units used a 1N4001 (1 Amp rated)
other references I have are to a 1N4935 (also 1Amp rated)
Concur , especially with the SMD transistors on this board.
You may wish to do a continuity test (From Brown, to each of the blues (Gr/Rd) )
if you have a direct short , one of driver transistors has failed and may be the root cause. (i.e. the diode would have got hot but may not actually have failed before the controller cutout.
In my experience (which are only a couple - these are good/tolerant devices) , if there was only one fault (Yellow IN as Tom mentions) , the diode should be able to be replaced to get you operating again.
Offline PMPeter
#7 Posted : 30 June 2016 04:38:13(UTC)
PMPeter
Continuity check between the brown and each of the 8 blue lead sockets are all open circuit, so it looks like it is just the diode.
I checked out both of the diode numbers that you provided and they all appear to be single banded units. Any idea why the Marklin installed component has 2 bands? Is it perhaps a special component?
So if I understand both you and Tom correctly, if I scrape off the connection between DATEM and +UB I can feed the K83 red digital power connection at the top of the K83 and from another source to the red plug at the bottom of the K83, similar to the Viessmann 5211.
Offline PMPeter
#8 Posted : 30 June 2016 04:42:18(UTC)
PMPeter
Thanks. Perhaps when you are home you can look at my photo and see if you have an idea why the failed unit has 2 bands.
Offline Shamu
#9 Posted : 30 June 2016 04:51:59(UTC)
Shamu
The diode in question is a 1n4935. From memory the dual bands most likely indicate Russian (or Soviet) manufacture.
EDIT:
Whoops, sorry Peter just realised you had mentioned that Blushing .
This page was generated in 0.354 seconds.
