#1 Posted : 09 May 2016 22:43:46(UTC)
Hi everyone,
I'm working on a bit of an experiment, and I'd like to use the older style Marklin catenary for it. I love the system, and it is much easier to have on a layout due to the pieces being able to click in an click out in case of accessing derailments etc...
Now my one big complaint is the chrome/stainless/??? bright wire coloration. What material is this? Stainless Steel?
What I'd like to do is use a solution like "blacken it" (which I understand is no longer available?) or "NeoLube" to darken the wire but retain conductivity. Are there any metallurgists out there who can advise on material, or a solution that might work?
Once I have an idea of what I'm working with, I'll post images of my test pieces for all to see
Offline dominator
#2 Posted : 09 May 2016 23:19:31(UTC)
dominator
Hi everyone,
I wonder if coating the surface with a "phosphoric acid" based product [ like they use when they "blue" rifle barrels ] might work. Wurth makes a product called Rust Converter which turns blue/black on application. Trouble is , it comes in 1 litre bottles.
Dereck
Offline Marty
#3 Posted : 10 May 2016 00:33:07(UTC)
Marty
I used the product "Blacken It" years ago to blacken the nickel-plated pantographs of my 194 electric loc. I found it was difficult to control the end results - in some areas the nickel was nicely toned down, and in other areas the acid burned right through the plating. The end result was kind of a dark and flakey finish, not a uniform finish at all. Also, when you're done, you have to neutralize everything in a baking soda solution. If you have the 2003/2004 Märklin catalog handy, take a look on page 161 and 171: It looks like the catenary wire was dipped in the same product, with the same results! I don't like working with dangerous materials, and disposing of the waste is also a hassle - you can't just pour it down the drain.
I think you'd be much better off airbrushing the wire, or just let it be. My wire is so old, that the nickel is no longer super shiny anymore, and it looks ok to me. But maybe someone else here has been down this road and can give better advice.
Marty
Offline analogmike
#4 Posted : 10 May 2016 01:16:29(UTC)
analogmike
Real catenary is copper. When it oxidizes it turns jade green like a New York Central caboose.
Mikey
thanks 4 users liked this useful post by analogmike
#5 Posted : 10 May 2016 23:01:27(UTC)
Hi everyone,
I think you will find the catenary is stamped brass that is then nickel plated.
Offline GLI
#6 Posted : 11 May 2016 11:55:02(UTC)
GLI
I don't think the old catenary is brass. It rusts. More likely it is stamped from a mild steel.
Geoff
Offline analogmike
#7 Posted : 11 May 2016 12:33:46(UTC)
analogmike
No not brass, when I chop it for alterations no gold color is inside. It is very soft. It may have some zinc or lead mixed in with god knows what they had lying around.
Maybe best we don't know. I don't want to put on a hazmat suit to play with my mrr. Mikey
#8 Posted : 11 May 2016 16:54:34(UTC)
Thanks all for the replies. If its nickel plated it may be tough to blacken. I need to sort whatever the best replacement for blacken it is these days and give a test piece a shot. I can't really paint as I want to retain the conductivity. (or I could leave the lower lip of the wire unpainted but that already smells of operating failures)
Ideas for a blackener are welcome! Its on the experimentation list until I sort that part out.
#9 Posted : 11 May 2016 23:41:33(UTC)
OK, if the base metal is a steel item, then the plating may be chrome, which would be a nice hard surface for the pantos to rub on. How much does the catenary wear with use?
#10 Posted : 11 May 2016 23:58:00(UTC)
it is funny you mention is as I thought it might be chrome, but I know that process is really expensive. I'd say it doesn't wear at all- it only wears the pantographs themselves out...
Offline Marty
#11 Posted : 12 May 2016 00:22:57(UTC)
Marty
The recently posted video of the Märklin manufacturing process shows the catenary wire coming out of the plating bath. It is at 4:05 into the video. The video was posted under this topic heading: Vintage Märklin promotional film from the 70's
Here's the link:
https://www.marklin-user...m-from-the-70-s--English
Marty
thanks 1 user liked this useful post by Marty
#12 Posted : 12 May 2016 08:46:09(UTC)
Whatever you do you are going to have to clean up at least two areas....
1: The underside where the Panto rubs
2: The inside of the holes where the mast wire attaches
I was going to suggest painting also, partly because it's the quickest method and probably the easiest.
But you'll probably also want to blacken the afore-mentioned Mast support wires as well.
I reckon you'll maybe find it just as easy to paint them 'in-situ' using an over-spray guard. This should maintain most of the existing connectivity at the masts.
While the paint is still wet you could easily wipe the underside to keep that clean and finally attach a bit of fine emery paper to a couple of panto's and run a train around to buff them up.
Just a thought?
Cookeee
#13 Posted : 12 May 2016 15:26:20(UTC)
Thanks Cookee. Thats plan B to blackening as I don't have patience or budget for sommerfeldt. (at least not when there is a perfectly good alternative), and the old Marklin system offers the level or both modularity, reliability, and ease of access to any train wrecks that I really desire.
Might be a few months, but I'll keep everyone posted...
#14 Posted : 12 May 2016 15:28:00(UTC)
Here's the link:
Well that gives us one answer- nickel plated...
Offline danmarklinman
#15 Posted : 13 May 2016 13:28:45(UTC)
danmarklinman
Here's the link:
Hi, I painted mine, and then regretted it. I removed the paint as it just made it look bigger than it was? My personnel advice. Is to leave it as is. Then you can take it down and put it up as you want. It's good stuff and they should never stopped making it:-( cheers Dan
Wiking model car Fan
Instagram: marklin1978
Wiking fan
Offline Torstein
#16 Posted : 13 May 2016 16:03:35(UTC)
Torstein
Hi, I agree with Dan above, don,t paint them.
There are many thinks that look "ugly" when it stands alone, as self-made threes, different thinks in the landscape, Marklins clumsy centenary and so on. But believe me, when you put in a bigger picture, as a layout with a lot of details, it will not stand out in the spectators eyes.
I like this centenary because its solid and you can use a solder iron if it don,t fit properly. After 25 years I have never been needed to adjust it, if may hands should have touched it in tunnels or difficult places.
Be careful where you place the mast as many wagons are longer today.
Have fun.
Torstein
https://www.youtube.com/user/TheMagictrain
thanks 2 users liked this useful post by Torstein
#17 Posted : 14 May 2016 17:06:29(UTC)
Thanks everyone, the systems robustness is what I need for my plan of attack as I am going for functional catenary on the project, yet I will need train wreck/maintenance access to it in strange places and that writes sommerfeldt off. (nevermind the installation and adjustment headaches)
Posting in the wanted section for the items I need, but this should be fun once I sort a way to blacken the wire.
Note the black catenary in the 1990 catalog, although it looks painted:
http://www.modelleisenba...lin/pdf/MA1990_EN_IT.pdf
#18 Posted : 20 May 2016 09:08:54(UTC)
danmarklinman
Hi you can also use Electroten overhead poles. As I believe they were made similar overhead. I also use the SNCF style 25kv poles and kit built masts.
heres a bit of my layout with the Marklin overhead and different styles of overhead support poles, some are Electrotren, some are Altered Marklin and others are Marklin supports on kit built gantries? All made to look like SNCF 25 kv ?
https://www.google.co.uk...#imgrc=N0zDoyn5uSJlNM%3A
Edited by user 20 May 2016 19:22:44(UTC)  | Reason: Not specified
Wiking fan
Offline Marty
#19 Posted : 23 May 2016 05:17:32(UTC)
Marty
Maybe you could experiment with permanent felt-tipped markers. I was in an art store and noticed a line of markers in various wood tones. The dark mahogany might look good on the wire. If you don't like the finish, you can easily remove it with isopropyl alcohol on cotton swab.
Just an idea since we're still in the "Research and Development" phase...
Marty
#20 Posted : 24 May 2016 22:32:20(UTC)
And a good idea! Stay tuned!!!
This page was generated in 1.023 seconds.
