Offline Marty
#1 Posted : 09 May 2016 21:36:06(UTC)
Marty
I'm thinking of buying an E44, specifically the 37442 version. This bogies of this version, unlike earlier versions, have a total of 16 sandboxes (4 per axle). Earlier Märklin versions of this have 2 sandboxes per axle. My question is this: Are the bogie frames metal castings on this model, or are they plastic? If they are plastic, is it possible to remove the inner sandboxes, leaving the bogie frame looking like earlier versions of this model? Or, could I order bogie frames intended for an earlier version, say the 37440, and swap them?
Finally, I would be interested on any feedback on the new tooling E44 (34440, 37440, 39440, etc.) that anyone here may have.
Marty
Marty
#2 Posted : 10 May 2016 03:55:16(UTC)
Originally Posted by: Marty Go to Quoted Post
I'm thinking of buying an E44, .....
Marty
Hi Marty,
I have a 37440 purchased 8 years ago, brand new, and it happens to be running on my layout as we speak.
I like the locomotive, it looks good, and I have never had any problems.
I use it on catenary with pantographs up.
But I guess it has a very outdated type of decoder, because the speed steps are not as smooth as my more recent engines.
I don't know if I can tweak that by choosing a different speed profile from my CS1.
Offline applor
#3 Posted : 10 May 2016 07:03:40(UTC)
applor
I also have this model.
It has the 6090x series of decoder, which means Marklin Motorola with 28 speed steps. DCC/MFX have 128 speed steps.
Still, it's a lot better than those early cheap decoders with 14 speed steps.
I love the early generation e-loks, I have the E04, E10 ('54 prototype), E17, E19, E32, E44, E75, E91, E94
#4 Posted : 10 May 2016 07:55:12(UTC)
Those DIP switch fx decoders support 27 speed steps (but not 28 speed steps), so for best results select MM27 (or a similar name) for that loco.
To increase smoothness, use the pot on the decoder to set a longer acceleration/braking delay.
IMHO such an old DIP switch decoder with 27 speed steps is smoother than the new mfx decoders with 126 speed steps. I never use more than 28 speed steps to run my trains and let the decoder ABV do its job.
The programmable fx decoders of 2004 supported 28 speed steps, but were soon replaced by cheap fx decoders with 14 speed steps only.
Offline Marty
#5 Posted : 10 May 2016 17:47:36(UTC)
Marty
Thanks for the responses, guys. I will probably just look for a used 37440. It will run well enough for me and I prefer the bogies with only 2 sandboxes per axle. The majority of prototype pictures I have found on the internet show the bogies only equipped with 2 sandboxes per axle. The 4 sandboxes per axle seems to be unusual among the fleet of E44s.
Marty
This page was generated in 0.417 seconds.
