Offline danmarklinman
#1 Posted : 20 April 2016 14:30:36(UTC)
danmarklinman
Dear all, if anyone has one of the Marklin rbe 2/4 Sbb electric railbus, could you please take some measures from it for me. It is because I wish to use the chassis to convert a static SNCF railbus into a working model.
The measures I would like are- from the point between the centre of each bogie, to the other, and the whole length and width of the chassis.
This is the Marklin railbus I need
https://www.google.co.uk...#imgrc=Gk1J69S6F7SRqM%3A
Wiking model car Fan
Instagram: marklin1978
Wiking fan
Offline Gregor
#2 Posted : 20 April 2016 15:20:13(UTC)
Gregor
I have the blue OeBB version. I can only get the info late tonight, maybe even tomorrow. If nobody provides the information before that time, I will get it for you then.
Gregor
thanks 2 users liked this useful post by Gregor
#3 Posted : 20 April 2016 18:26:33(UTC)
danmarklinman
Gregor
Thanks, that would be great.Dan
Wiking fan
Offline Markus Schild
#4 Posted : 20 April 2016 22:15:49(UTC)
Markus Schild
The chassis is 30.4 mms wide, center bogie <-> center bogie 188mm (+/-1mm), total length of the chassis is 242 mm (+/-2mm). Hand-measured.
Markus
Offline Gregor
#5 Posted : 20 April 2016 23:37:46(UTC)
Gregor
I got these:
a: length over buffers 258 mm
b: length over body 247 mm (chassis is shorter indeed like markus measured)
c: length between bogie pivot points 195 mm (pivot point is off center)
d: length between bogie center points 187 mm
e: body width 34 mm
Good luck,
Gregor
thanks 5 users liked this useful post by Gregor
#6 Posted : 21 April 2016 11:05:35(UTC)
danmarklinman
Thank you so much, that's really helpful. This the forum at its bestBigGrin
Wiking fan
This page was generated in 0.283 seconds.
