#1 Posted : 17 February 2016 01:59:25(UTC)
Hi everyone,
Random question- can a Marklin digital 5558 Crocodile be run on DC power like an LGB system? It is digital, so I would assume so, but thought I'd ask efore I fry something!
Advice is appreciated, the paperwork it came with is only a parts list and a certificate, no owners manual. Marklin has the newer Croc manuals online, but I wasn't sure if this has the same digital electronics?
#2 Posted : 17 February 2016 03:21:33(UTC)
Hi John, Yes apparently the 5558 Crocodile can be operated with DC.
Here is the description from the 1994 Marklin catalog.
Offline Markus Schild
#3 Posted : 17 February 2016 14:43:06(UTC)
Markus Schild
Yes, it can run on DC. It has a switch on the underside of the middle-part to set the operation-system. But on a LGB - layout you must be very careful. LGB - transformers have an output of up to 24VDC which is to much for the loco (max 14 VDC).
Markus
Offline AshleyH
#4 Posted : 17 February 2016 14:52:30(UTC)
AshleyH
Yes I agree with Markus, I was just logging on to make the same point.
LGB DC controllers put out too high a voltage, usually around 22v, even the newer switch mode power supply ones still put out 19v which would risk damaging the electronics of the loco.
If you want to run on analogue, maybe try a Marklin 6647 AC controller.
Best Regards
Ashley
#5 Posted : 17 February 2016 16:44:33(UTC)
Thanks all! Good to know on several counts- particularly the voltage issue/compatibility with DC...
Offline biedmatt
#6 Posted : 17 February 2016 20:13:17(UTC)
biedmatt
Matt
Era 3
#7 Posted : 17 February 2016 20:38:17(UTC)
Thats the one! Time to let her go and I wanted to be sure I listed it right for DC operation...
1 scale plus a NYC apartment are not a good mix. (according to the FD!!!)
Offline biedmatt
#8 Posted : 17 February 2016 21:24:03(UTC)
biedmatt
Hi John, When I saw the seller's name I knew it was you.
Matt
Era 3
Offline jdpb63
#9 Posted : 23 February 2016 19:28:04(UTC)
jdpb63
Aargh! I was the high bidder at T-4 seconds. Really wanted it, but couldn't bid higher w/o getting killed by my wife. (Even at my high bid, I was going to have to hide it from her somehow ;)
Still, someone got a great deal.
Cheers!
This page was generated in 0.541 seconds.
