Offline cfpedro
#1 Posted : 10 February 2016 12:41:24(UTC)
cfpedro
I have a Mobile Station 60652 with a 66191 (18 VA) Transformer and a Feeder Track 24088. My question is can I use non digital trains with it ?
Carlos
#2 Posted : 10 February 2016 12:50:43(UTC)
Hi, Carlos!
Originally Posted by: cfpedro Go to Quoted Post
My question is can I use non digital trains with it?
Not really.
Analogue locos will run until you press stop, but there is no way to control the speed or change the direction.
Offline cfpedro
#3 Posted : 10 February 2016 12:53:15(UTC)
cfpedro
I've tried a few Analogue trains and none of them respond, so can I presume the 60652 is faulty ?
#4 Posted : 10 February 2016 13:53:58(UTC)
Do you see symbols on the display of the 60652? Can you flip through the menus? Does it respond to pressing STOP (there should be a STOP symbol on the display that can be toggled).
Do the analogue locos have centre rail sliders? Do they make any sounds?
Offline cfpedro
#5 Posted : 10 February 2016 14:57:00(UTC)
cfpedro
When you power on the Marklin logo comes on then it comes up with V160 10. If you press the stop button the stop icon comes on the screen. If you turn the red knob clockwise the speed display increases. I ve tried a 3074 DB BR 216 188-3 which is a Delta train but now the 60652 is continuously saying address. used and a lot of characters keep on displaying in a loop, can't "esc" out of this loop.
#6 Posted : 10 February 2016 15:08:18(UTC)
A Delta train is digital, not analogue. Make sure the DIP switches on the Delta decoder are set for digital operation.
To get rid of the address error, make a factory reset for the Mobile Station and register the loco again.
Offline cfpedro
#7 Posted : 10 February 2016 15:33:48(UTC)
cfpedro
A preset ?
If that, I've done it twice. When i try and add it in it says address already used
Offline cfpedro
#8 Posted : 10 February 2016 15:46:45(UTC)
cfpedro
I got it to take address 72 but still nothing happens, i suspect the problem lies with the Feeder Track 24088
Offline cfpedro
#9 Posted : 10 February 2016 16:43:57(UTC)
cfpedro
I took my 60215 out the box and tried my 3074 it runs like a dream. I'm trying to get a little set up for a friend and I wanted to use the 60652 with a 66191 (18 VA) Transformer and a Feeder Track 24088 combination.
Offline mbarreto
#10 Posted : 10 February 2016 17:03:31(UTC)
mbarreto
A Preset of the MS should put the MS with factory defaults without any loco.
I suggest you try again do a preset like in page 6 of the manual:
MS Manual
Miguel
Mostly Märklin H0.
Offline cfpedro
#11 Posted : 10 February 2016 17:35:11(UTC)
cfpedro
Thank U very much Tom for the help :)
Carlos
Offline cfpedro
#12 Posted : 10 February 2016 17:44:02(UTC)
cfpedro
Thank U mbarreto :)
Offline cfpedro
#13 Posted : 10 February 2016 17:58:01(UTC)
cfpedro
Ok good news the 3080 and the 3074 are both running now, I reset it for the third time, set it up 1st time, clean the track up :)
Carlos
thanks 1 user liked this useful post by cfpedro
This page was generated in 0.441 seconds.
