#1 Posted : 24 January 2016 20:58:00(UTC)
I wrote up how I install signals on my layout:
http://cabinlayout.mixmox.com/1/Installing-signals
thanks 11 users liked this useful post by DaleSchultz
#2 Posted : 24 January 2016 21:40:03(UTC)
Some good tips there Dale, thanks for posting.
I find that the wires on the Viessmann signals are very fine and can easily break, but the break point is usually where the wire connects to the in-line resistor. It isn't too hard to repair if the wires do break - I usually use a new piece of white heatshrink, and then paint the heatshrink to match the original colour.
Offline kamstutz
#3 Posted : 24 January 2016 21:57:43(UTC)
kamstutz
Dale - Thanks for documenting this "Signals How-To". The time you spent photographing each step is so much more helpful than a text based step-by-step. I've just bookmarked this page on your layout website so that I can revisit it when I get around to setting up my signals.
Online kimballthurlow
#4 Posted : 25 January 2016 02:30:03(UTC)
Thanks Dale, for an interesting "how to".
I liked the ruler holding the three signal posts for better alignment before gluing.
#5 Posted : 25 January 2016 05:11:42(UTC)
Dale, the only suggestion I would make when using a shrink tube to cover the resistor as well, this will prevent the wire to bend at the given joint and may result in breaking off as Dave indicated.
Offline dennisb
#6 Posted : 25 January 2016 09:29:16(UTC)
dennisb
Thanks a lot for the great inspiration!
BR
Dennis
#7 Posted : 25 January 2016 11:38:18(UTC)
Thank you very much.ThumpUp
#8 Posted : 28 January 2016 20:18:11(UTC)
Hi John, the resistors have to dissipate heat and should not be insulated with heat shrink. I even mention that in the text I think.
This page was generated in 0.504 seconds.
