Offline mbarreto
#1 Posted : 19 January 2016 18:06:29(UTC)
mbarreto
Have you tried using the mDecoderTool mDP using the CS2 instead of the mDecoderProgrammer mDP 60971?
I installed the mDT in the PC, selected english and it seems working well except in the connection to the CS2. I don't have a mDP.
If you had sucess, did you do something special in the PC or CS2 for allow this to work? I have IP connectivity between both (ping and browser access). Didn't sniff the connection yet...
Miguel
Mostly Märklin H0.
Offline pietercc
#2 Posted : 20 January 2016 03:35:36(UTC)
pietercc
hello Miguel,
I have a mDecodertool and i have had minimal success at using it with the CS2. First you have to make sure that the CS is connected to the internet, and then open the mTool on your laptop. To test the connection do something simple like change the address, then click on the photo of the CS2 that is on the left hand side. the download symbol should darken and now let you press it to down load to the CS.
So far that is as much as i have figured out.
Hope this helps
Pieter
thanks 1 user liked this useful post by pietercc
This page was generated in 0.318 seconds.
