Offline nelson77
#1 Posted : 03 January 2016 21:17:31(UTC)
nelson77
Have not used my two cs2 that are linked together. Been a couple of years. When I turned on all looked good except none of my data is loaded. I though I might as well up grade. Can someone give me the site in English in order to upgrade my CS2's,
Nelson
#2 Posted : 04 January 2016 00:51:33(UTC)
The web page that refers to this subject is http://www.maerklin.de/d...ervice/software-updates/
There is no English site for this. You may use Google and translate
However, you are usually better off connecting the CS2 to the internet and letting it do the update itself.
Depending on how down level your existing unit is, it may require a couple of updates/reboots - be patient.
Offline nelson77
#3 Posted : 04 January 2016 16:28:46(UTC)
nelson77
Thank yo clapcott,
Do I just plug it into the internet and than it downloads on its own?
Nelson
#4 Posted : 04 January 2016 16:55:26(UTC)
You have to start the search for updates manually on the Setup screen.
For versions prior to 3.6 update has to be started twice as the update mechanism was changed.
Offline nelson77
#5 Posted : 04 January 2016 22:17:37(UTC)
nelson77
Follow up.
I was able to down load and up grade both of my C2's. I did notice under 'information ' on one of my units did not have any information listed on it. The other one showed some power graphics under information. Did I mess up the download some how?
Nelson77
#6 Posted : 04 January 2016 22:25:25(UTC)
Maybe the master unit can show graphs for both units - there is a dropdown listbox for unit selection on that page.
Just a guess, I don't have experience with CS2 master/slave configurations.
Version information can be found on other screens.
Offline nelson77
#7 Posted : 05 January 2016 16:05:21(UTC)
nelson77
Thanks Tom,
I will try latter today and install it back to the layout.
I noticed there are several files to back up. Do I back all of them too th thumb drive.
Nelson
#8 Posted : 05 January 2016 19:34:13(UTC)
Nelson,
There is a Backup button on the setup page. Click it, enter a name - and AFAIK this single file is all you need. Backups can be written to thumb drive or internal storage.
If you include date and "master" or "slave" in the file name then you will know what it is and when it was made - when you need it one day.
The thumb drive should be able to hold hundreds of backups, so you can keep a long history on the thumb drive.
Offline nelson77
#9 Posted : 06 January 2016 17:04:43(UTC)
nelson77
Thanks Tom
This page was generated in 0.734 seconds.
