Offline Carlos
#1 Posted : 09 November 2015 19:09:04(UTC)
Carlos
Hello to everybody: I have been trying in different ways to connect the track 24997 to the decoder 60831 and then to the Central Station 60215. I received few answers in the past from this forum, but my problem still when I try to program the Central Station. Do anybody know about a web page with information step by step. Thank you in advance.
Carlos
Offline waorb
#2 Posted : 10 November 2015 20:06:07(UTC)
waorb
Brazil
Offline Carlos
#3 Posted : 12 November 2015 02:46:05(UTC)
Carlos
Thank Walter but my problem is not with the MS 2, is with the CS2 (60215) The problem is how I program the 60831 (with the 24997) in the CS2. Thank you ,
Carlos
Offline Timnomads
#4 Posted : 12 November 2015 09:37:14(UTC)
Timnomads
Hi Carlos
I am also interested in doing the same thing, and seeing you are having trouble getting an answer, I have put the same question to Marklin support and am awaiting an answer. I will post here when it comes.
Tim
Offline Carlos
#5 Posted : 12 November 2015 19:17:08(UTC)
Carlos
Hi Tim, Ok, lets just wait, at least I'm not the only one.
Carlos
Offline Timnomads
#6 Posted : 20 November 2015 13:14:29(UTC)
Timnomads
HI
Here is the reply from Marklin :-
The decoder 60831 will be connected over the brown and red cable
to the output for the layout of the central station. Instead of one
turnout you can connect two uncouplers 24997 to one of the four
connections of 60831. Both yellow cables of the both uncouplers are
connected to the middle plug in. one blue to the right and the other blue to the left
plug in of this connection. That’s all.
For the CS2
Please go to the “Keyboard” in the CS2. Click then at the left side
to the “configuration-key”. Now you can select the button on the
Keyboard on which do you want to install the uncoupler.
In the configuration of this button you must select as Decoder Type “new multidecoder”
and as Type “Uncoupler Track”.
thanks 2 users liked this useful post by Timnomads
Offline Carlos
#7 Posted : 22 November 2015 01:46:20(UTC)
Carlos
Thank you Tim, I'll try no this but next weekend,
Carlos
Offline waorb
#8 Posted : 23 November 2015 13:50:55(UTC)
waorb
Brazil
Hello.
I missed this conversation for a while, but here are some photos of my CS2 with K83 and the uncoupler.
Maybe is an example of configuration.
Walter
Connecting track 24997 (Digital)
by Carlos 12/08/2015 03:47:27(UTC)
Can MS2 control Uncoupler Track 24997 (Digital)
by adelrs 18/06/2014 13:05:48(UTC)
This page was generated in 0.398 seconds.
