Offline joseluisvalde
#1 Posted : 16 November 2015 16:33:00(UTC)
joseluisvalde
I tried to correct defects in a MSD decoder Marklin 60947 but the result has been disastrous: now only the lights work; no sounds.
I downloaded the library of sounds directly from the website marklin with CS2 (24 hour discharge!) in a 1GB memory stick. It occupies almost 500MB.
Well then when I go to mode programming, and I click in Upd,it recognizes the decoder SMD but when I want to load data lines "decoder FDS and Sound Flash" nothing or very little information appears, and if I apply any of them it said "flash file is missing", or something so.
Somebody can help me?.
Jose Luis
#2 Posted : 16 November 2015 19:29:22(UTC)
Same problem discussed in this thread:
https://www.marklin-user...ashing-sounds-into-60940
No solution yet.
But others reported that they can still do sound updates.
#3 Posted : 16 November 2015 20:18:33(UTC)
joseluisvalde
Thanks for your help Tom.
But the problem that I have is that after being downloading during 24H the sound Bibliotek to CS2 connected to the Internet, and check that the USB are loaded with aprox 500MB into folders like CS2 , etc., when I try to do the update in the loko, no locomotive appears (or just 2 msD) on the information that I upload; that is, I can not put anything in the second line "Decoder FDS", or in the fourth line " Sound Flash".
I repeated three times the download operation
Please, I will thank any help
B.R.
Jose Luis
#4 Posted : 16 November 2015 20:38:40(UTC)
Theoretically you can take an empty USB drive, download a single decoder project (about 2 MB) from the Märklin site to the USB drive, then plug that drive into the CS2, wait a few seconds, and try if it works.
Is the sound you want listed on their site?
Link to the German site:
http://www.maerklin.de/d...er-updates/dampf-sounds/
#5 Posted : 16 November 2015 22:11:18(UTC)
joseluisvalde
Yes, I have also tried to download sounds of a single locomotive (in my case, electric crocodile) into an empty USB, but it has not worked.
jose Luis
#6 Posted : 17 November 2015 21:04:52(UTC)
joseluisvalde
I'm at a dead end.
Surely there must be a reason unknown to me, but neither downloading the entire Bibliotek of sounds, or downloading as explains Marklin (with a single locomotive sounds), I do not get data displayed in the second line "Decoder FDS" of the program .
The CS2 - 60214 is updated to the latest version 4.1.0.
A help! please.
Jose Luis
#7 Posted : 18 November 2015 12:27:05(UTC)
joseluisvalde
I return to the subject to give more clues, which do not help me.
Nothing appears on the line "Decoder FDS" although checking in "status" if there is data.
In the fourth line "flash sound", the required data are obtained.
If I try to load without data in the second line, the following appears:
"For a network device, information file is missing or flash file"
I do not understand and do not know how to act.
If anyone can help me....
Jose Luis
#8 Posted : 18 November 2015 16:22:46(UTC)
Did you restart CS2 after the download?
If i understand right,you must shut down CS2 and restart it.
24 hours discharge seems extrem...
#9 Posted : 18 November 2015 16:50:27(UTC)
joseluisvalde
Thank you for the recommendation. I probably did not do after download the entire sound Bibliotek , but I think I did itself in other intervals.
I will try to do this you're saying, but the fact that data from one single locomotive not appear in the line "Decoder FDS" is very strange.
I will keep you informed if I get some results.
Any comments will be welcome, because I feel lost.
#10 Posted : 18 November 2015 18:18:45(UTC)
joseluisvalde
I have come to a standstill.
At first I wanted to add some sound to decoder mSD 60947 and the only thing I got was that all sounds disappear. They only were the lights and movement.
Now, after twists and turns everything has gone out, and all the icons have become as sound generic, but no sounds, no lights, no movement.
My mood is in tatters.
Jose Luis
This page was generated in 0.478 seconds.
