Offline mancsaint
#1 Posted : 01 October 2015 00:19:40(UTC)
mancsaint
I have eleven sets of turnouts to control using 2 x Kuehn WD10 decoders (87010) with an Intellibox 1 (65000).
Have been using one WD10 with no problems, do I just put another set of wires where they are put for one WD10? The Marklin K83 (60831) has an input and output for next decoder, the WD10's do not.
How do I connect both WD10's to the IB?
I'm lost and any help would be of great assistance.
Mancsaint
Offline gwolski
#2 Posted : 01 October 2015 01:27:35(UTC)
gwolski
Both connect to the track output from the IB - here's a wiring diagram (assuming external power). You will need to configure the decoder addresses for the second WD10 to be different from the first. It looks like the WD10 has two output groups, each requiring an address.
Link to WD10 Manual
Gene Wolski
Offline mancsaint
#3 Posted : 01 October 2015 01:55:37(UTC)
mancsaint
I was thinking that connecting both was the possible answer but what put me off was say six or seven WD10's? How would you insert all the connections into the IB?
My problem is solved, thank you, but what is the answer to my supplimentary question?
Sean aka Mancsaint
Offline gwolski
#4 Posted : 01 October 2015 02:01:43(UTC)
gwolski
You can use a distribution strip or terminal block to make the connections neatly. It also sounds like you'll want to use external power for the WD10's. Does that help?
In the picture, track output goes to A and B, and each accessory needing digital connection connects to the strips.
Gene Wolski
Offline mancsaint
#5 Posted : 01 October 2015 10:37:51(UTC)
mancsaint
Thank you Gwolski problem solved.
Sean aka Mancsaint
This page was generated in 0.586 seconds.
