Offline arrate
#1 Posted : 16 September 2015 23:00:39(UTC)
arrate
As you begin to program a route in memory, the station I get a instrucion says (distance between the two stations on the route) to the keyboard I indicated a mumero for example 4, I understand that there are 4 mts. but the train does not stop. There only to stop the timer or traffic lights. this
Offline Hackcell
#2 Posted : 17 September 2015 01:06:02(UTC)
Hackcell
Costa Rica
I think you care confusing the s88 port address with the distance. There is not a distance variable set per se in the CS2 memory setup. Can you please take a picture and upload it?
Buenas,
Creo que confundís el puerto del s88 con la distancia. No existe una variable de distancia per se en la configuracion de memorias de la CS2. Podés tomar una foto y subirla?
Danilo Jiménez
Costa Rica, pura vida!!
Offline arrate
#3 Posted : 17 September 2015 12:38:32(UTC)
arrate
Hola Danilo. Como veo que eres de Costa Rica te voy a contestar en castellano. Me arreglo mejor que traduciendo a traves del traductor de Google. No te envio la foto porque no se como se hace. pero te lo explicare mejor.
Al abrir una ruta lo primero que hay que llenar son los datos de la estacion de partida
STATIONNAME San Sebastian
TRACKSECTION LENTGTH 4
DELAYTIME 00.00.02.35
Lo que te quiero decir es que importacia tiene ek valor de 4 o dicho de otro que pasaria si pondria 40
Offline Hackcell
#4 Posted : 17 September 2015 15:49:51(UTC)
Hackcell
Costa Rica
Translation
Hello Danilo. As I see that you're in Costa Rica I'll answer in Castilian. I fared better than translating through the Google translator. I did not send you the picture because I don't know how it's done. therefore I'll better explain you.
When opening a route first thing to do is to complete the departing station data:
What I mean is how important is the "4" value, meaning what would it happen if I change it to 40?
Danilo Jiménez
Arrate (Digital)
by arrate 13/10/2015 12:57:31(UTC)
arrate (Digital)
by arrate 10/09/2015 22:17:57(UTC)
Arrate (Digital)
by arrate 07/09/2015 10:17:52(UTC)
This page was generated in 0.341 seconds.
