2 Pages12>
Online Alsterstreek
#1 Posted : 08 February 2015 16:34:53(UTC)
Since I swapped my European collection against an US-style one, I carried out a number of alterations and which qualify as kit-bashing. Therefore, I decided to group them here. I start with an overview of 2014 works.
thanks 15 users liked this useful post by Alsterstreek
Online Alsterstreek
#2 Posted : 08 February 2015 16:56:30(UTC)
The first 2015 project - Frankenstein M* streamliner coach: Leftovers from at least two deceased coaches combined with various spare parts (as coupler mechanism and springs), silver spray-painting of formerly black trucks and a pragmatic solution for a front vestibule (spray-painted thick cardboard) which (a) looks acceptable when close-coupled to another coach in front and (b) works even on R1 curves.
Edited by user 04 September 2015 21:39:14(UTC)  | Reason: typo
Online Alsterstreek
#3 Posted : 01 September 2015 23:14:30(UTC)
The early EMD GP locos hat the same wheelbase and trucks as the EMD F units. Thus I decided to try to fit a GP7 (or GP9) shell by Athearn on the Maerklin F7 undercarriage.
Lenght and width are matching, and the motor might even have enough room of manoeuver under the wide cab, but unfortunately the metal edges of the Maerklin chassis are too high.
Then, adapting couplers would have been another challenge...
Offline 3rail4life
#4 Posted : 02 September 2015 03:54:47(UTC)
3rail4life
Very cool Ak ThumpUp ThumpUp, I have couple kitbashing US prototype projects in the works, I will post some pics here when they get done...
Gordon
thanks 2 users liked this useful post by 3rail4life
Offline Hackcell
#5 Posted : 02 September 2015 05:39:21(UTC)
Hackcell
Costa Rica
BRAWA 0999 is useful to have the NEM couplers adapted.
Danilo Jiménez
Costa Rica, pura vida!!
thanks 2 users liked this useful post by Hackcell
Online Alsterstreek
#6 Posted : 03 September 2015 14:23:04(UTC)
Double entry / deleted
Online Alsterstreek
#7 Posted : 03 September 2015 14:26:02(UTC)
Got myself a second shell for kit bashing.
Edited by user 03 September 2015 21:10:43(UTC)  | Reason: pic uploading problem
Online Alsterstreek
#8 Posted : 03 September 2015 23:07:30(UTC)
What can a man do with this (decoder/pick-up shoe, M* coupler)?
For a start, install one of the couplers.
Yes, I know, but I have mainly US tinplate freight cars with M* couplers at the bogies.
Reminds me that I still have to mount the missing front and rear railings.
#9 Posted : 03 September 2015 23:15:41(UTC)
Pity you couldn't shorten the shank a bit, just looks to be sticking out too far - but then you may need that on tight curves anyway.
Be interesting to see a 'helicopter shot' coupled to a wagon on an R1 curve.
Online Alsterstreek
#10 Posted : 03 September 2015 23:23:22(UTC)
As requested: helicopter view on R1.
Not the smoothest ride. Need to adjust, but I am only in the initial test phase.
;o)
Online Alsterstreek
#11 Posted : 05 September 2015 14:17:49(UTC)
Tight space: The decoder sits now under the cab in the space between cab roof and glass insert.
(Re-)cabling: All black cables go on one side now, connected to the black decoder exit cable. Orange and grey decoder exit cables soldered to either side of motor feeder plates (which - formerly connected to the "original" black cables - are now isolated), respectively. The single lightbulb remains in the middle, connected to both yellow and white decoder exit cables. Engine and light functions were tested in a "dry run" on a programming track.
Finally, the red cable goes to the "third rail" pick-up shoe. The latter is fixed with hot glue under one of the trucks. The pick-up shoe will be subject of the next post.
#12 Posted : 05 September 2015 20:17:47(UTC)
;o)
Thanks, looks like it would be fine with a shorter coupling shank, hard to tell with the lighting - don't worry, I'm not moaning.
I think you get away with it as the loco is reasonably short, about the same length as the gondola.
Online Alsterstreek
#13 Posted : 05 September 2015 21:40:21(UTC)
Found anyway a better coupler solution:
Short SYMOBA holder on the inside and a short M* coupler hook on the outside.
stays conveniently in place without screw or glue.
And looks "unsuspicious".
:o)
Online Alsterstreek
#14 Posted : 05 September 2015 21:41:52(UTC)
Front and rear platform railings are in place, too.
Online Alsterstreek
#15 Posted : 05 September 2015 22:24:48(UTC)
And now the announced "third rail" pick-up shoe installation report.
I had to shave off a lot of plastic under one truck - until the cog wheels were visible - to create enough space to allow the loco to glide over turnouts, with the curved turnout being the most challenging one. Actually, I had to shave off more material after taking the photo.
Here is the final view after fixing the pick-up shoe with hot glue. There is enough space in the middle of the truck to safely lead the feeder cable up to the decoder inside the housing.
Online Alsterstreek
#16 Posted : 05 September 2015 22:33:01(UTC)
I just finished the conversion job: Here is the proof:
:o)
#17 Posted : 05 September 2015 23:43:59(UTC)
That does look a lot nicer and less intrusive on the end not coupled.
What is the Marklin part number for that coupling - oh, and the symoba pocket?
Online Alsterstreek
#18 Posted : 06 September 2015 00:21:16(UTC)
Märklin 399740 "Kupplungshaken"
SYMOBA "Schacht kurz 110"
http://www.symoba-schniering.de/sym-produkte.htm
Edited by user 06 September 2015 10:43:15(UTC)  | Reason: Thread title adapted
#19 Posted : 06 September 2015 12:42:08(UTC)
Ah, thanks.
Online Alsterstreek
#20 Posted : 13 September 2015 23:45:41(UTC)
Another experiment that stalls for the time being. The idea is to have a Southern Pacific F7 ABBA consist in Black Widow paint scheme, made up of Athearn shells mounted on Maerklin F7 undercarriages. First, I installed window glazing on all Athearn shells (transparent one-size-fits-all scotch tape did the job). Then came the metal job: As the Athearn shells are slightly shorter than the Maerklin ones, the Maerklin undercarriages need to be sawed off to accomodate the Athearn shells. I started with the two F7B units. The Athearn shells fit well, but the Maerklin trucks do not move freely due to the position of the Athearn shell rear ladders. Thus, I pause until I found a solution before I assault the more precious motorized Maerklin F7A undercarriages. I post pictures of the F7A shells sitting on Tyco undercarriages with silver trucks and the F7B shells with prototypical black trucks mounted on Maerklin undercarriages . Eventually, all trucks are supposed to be black.sp4exp.pngsp2exp.png
Offline BrandonVA
#21 Posted : 14 September 2015 20:37:48(UTC)
BrandonVA
Ak,
There is no stopping the unquenchable thirst for B units and switchers:) Truly fantastic work, more guts than I have!
Now that you have ATSF and SP, I wonder what the next project could be...
ATSF Map...
Southern Pacific Map...
I am starting to see the overlay....
and what have we here?
D&RGW map.
Now we know you are the master of the EMD F7. The above reports suggest the same is true for a GP7/9 unit.
Now, F7s, B units, and GP9s! What more could you want?
Source: http://www.railpictures.net/viewphoto.php?id=251450&nseq=1
Hot Sulfur Springs, CO, 1957.
Ok ok, so maybe you think some other modeller should have a monopoly on D&RGW ;)
Maybe a compromise?
Source: http://www.railpictures.net/viewphoto.php?id=55165&nseq=63
Fort Worth, TX, 1966.
-Brandon
Online Alsterstreek
#22 Posted : 25 September 2015 21:06:52(UTC)
So the Geep is slightly taller than the F-units. I thought that my shells would not be to scale.
:o)
Online Alsterstreek
#23 Posted : 25 September 2015 21:08:25(UTC)
Another road name. M* UP caboose to become a D&RGW one.
Online Alsterstreek
#24 Posted : 26 September 2015 18:23:38(UTC)
Two Geeps without fuel tanks on the RIP track.
(Mock-up with partial cabin glazing and 2 mm cardboard "underbelly" sitting on two "loose" Tyco EMD trucks, respectively; to be continued)
Online Alsterstreek
#25 Posted : 27 September 2015 17:46:11(UTC)
Now with fuel tanks, close-coupled and trucks fixed (actually able to pivot).
Online Alsterstreek
#26 Posted : 27 September 2015 21:24:38(UTC)
Up and (test) running.
Offline BrandonVA
#27 Posted : 06 October 2015 20:23:49(UTC)
BrandonVA
Ak,
Just like the real thing!
Did you find it necessary to add ballast to the dummy units for better traction? And did you have to change the wheelsets?
-Brandon
Online Alsterstreek
#28 Posted : 06 October 2015 23:17:48(UTC)
I got away without extra ballast due to the weight of the full metal trucks. One truck per cannibalized Tyco loco had a cable connection and weird drum like axles, respectively. Only those trucks could be disassembled to receive pizza cutter type DC wheel sets (M* wheel sets did not fit). The second truck remained unaltered, respectively. That did the trick. Still, this is a hobby version which does not match true M* equipment driving performance.
Online Alsterstreek
#29 Posted : 07 October 2015 22:38:53(UTC)
Success, the SP F7 Black Widow ABBA set is up and running.
Online Alsterstreek
#30 Posted : 18 October 2015 23:31:22(UTC)
Tinkering...
Online Alsterstreek
#31 Posted : 19 October 2015 23:21:43(UTC)
When I grow up - or when the paint is dry enough to apply a red stripe at the bottom - I become a Santa Fe Alco PB unit.
Offline BrandonVA
#32 Posted : 21 October 2015 03:08:21(UTC)
BrandonVA
Tinkering...
Ak, this is the crowing achievement ;) Fast freight service demands B units to get "Through the Rockies"! Interested to see the final product.
-Brandon
Online Alsterstreek
#33 Posted : 22 October 2015 22:48:49(UTC)
The can rattling continued.
Next step is the black stripe between the silver and yellow parts.
Offline Yumgui
#34 Posted : 22 October 2015 22:54:21(UTC)
Yumgui
Just wonderful Ak, as usual ... !
Y Flapper
Online Alsterstreek
#35 Posted : 24 October 2015 16:25:38(UTC)
Now, that went better than expected: The Rio Grande F7B units with spray painted black stripes.
(Grab irons and fuel tanks still to be attached.)
Online Alsterstreek
#36 Posted : 24 October 2015 16:27:10(UTC)
The matching caboose received a silver roof to be closer to the prototype.
Online Alsterstreek
#37 Posted : 24 October 2015 23:14:58(UTC)
D&RGW F7 ABBA fast freight loco up and running.
Online Alsterstreek
#38 Posted : 01 November 2015 23:02:01(UTC)
ATSF Alco PB progress.
Offline BrandonVA
#39 Posted : 11 November 2015 13:54:03(UTC)
BrandonVA
Ak,
Those D&RGW B units (and caboose) came out perfectly. What did you use to mask the lines while painting? I have seen some small masking tape for modeling. Your lines look so clean, I was wondering if you had used something like that?
-Brandon
Online Alsterstreek
#40 Posted : 11 November 2015 18:35:31(UTC)
I used the best product, I could get here: tesa® 4333 PV1 Precision Mask® Sensitive
http://www.tesa.com/indu...on_mask_sensitive,i.html
Plain areas were unproblematic, but around the fixed grab irons at the corners and doorsteps required extra attention.
There isn't anything, tape can't fix:
#41 Posted : 11 November 2015 19:41:51(UTC)
Oh so that is how you transport your layout ... Scared Scared Scared LOL LOL LOL LOL
Online Alsterstreek
#42 Posted : 10 January 2016 15:10:09(UTC)
My first analogue to digital conversion of two F7As successfully completed. Process documented:
Online Alsterstreek
#43 Posted : 10 January 2016 17:50:11(UTC)
Quick headcount after the above operation:
6 x EMD F7 A-B-B-A in the stable.
Each with two motorized and two dummy units, respectively.
:o)
Offline BrandonVA
#44 Posted : 17 February 2016 14:48:37(UTC)
BrandonVA
:o)
What a sight! So many B units! I still can't get over how well those D&RGW B units match.
-Brandon
#45 Posted : 19 February 2016 01:48:48(UTC)
AK, I know its a bit late to respond to your conversion but my suggestion may help you in future. instead of filing and shaving off the plastic part I have added a electrical coupling and than used a carboose or anything similar to add the slider (elelectrical as well) but this means the loco is no longer travelling on its own and this is of course for 2 rail locos which can't be converted to 3 rail
Online Alsterstreek
#46 Posted : 19 February 2016 12:32:36(UTC)
... I have added a electrical coupling and than used a carboose or anything similar to add the slider (elelectrical as well) but this means the loco is no longer travelling on its own ...
Thanks John,
I might even follow this advice, as rolling over turnouts/switches/points (especially curved ones) is a challenge, because the pick-up shoe is lifting the loco a little bit. And as a busy shunter-gatherer, the loco should never move without a car.
:o)
Online Alsterstreek
#47 Posted : 13 October 2016 18:59:05(UTC)
Life Like Proto 2000 Santa Fe EMD E8/9 successfully converted.
Also not depicted: The distance between the wheel flanges on the front axle and the trailing axle have been reduced by pushing them gently together. I did this with two finger without dismantling anything. Before this intervention, the loco tended to derail when following the inner path of the R1 curved turnouts when "splitting the frogs". Now she is hovering over all C-track sections like a goddess.
Edited by user 13 October 2016 22:31:25(UTC)  | Reason: Not specified
Online Alsterstreek
#48 Posted : 13 October 2016 22:34:48(UTC)
Oh yes, where are my manners? Credits for alerting me about the opportunity to buy this loco go to BrandonVA. He informed also about the potential Maerklin-compatibility and good running characteristics.
Offline BrandonVA
#49 Posted : 24 October 2016 20:11:08(UTC)
BrandonVA
Recommendation, perhaps...but the guts and glory all go to the intrepid ATSF fan. I wonder if there are any additional conversions in the works?
-Brandon
Online Alsterstreek
#50 Posted : 25 October 2016 13:59:11(UTC)
There is something in the works. We are building an external power feeding device for converted former H0 scale 2-rail freight locos which do not offer enough space for installing a “center rail” pick-up shoe (converted passenger loco to be fed by coach equipped with Maerklin 73405 power feeder instead).
Ingredients: thinnest “Evergreen” white styrene sheet, 2 mm styrene rods, “Ibertren” article #9001 pick-up shoe for “three-rail” conversion, plastic glue, cable and soldering tools, screwdriver, sharp hobby knife, drill, Maerklin H0 gauge US flat car.
The works - (1) Build a well.
(2) Make shoe plate separately for easy adjustment when placing it in the center (see image #4 below). Hole is for later maintenance access to the screw holding the truck (shoe can be lifted after removing the two tiny screws).
(3) Truck and ring washer in place. White base plate fits nicely around raised round "thread housing". Subsequently the truck is attached with the existing screw (not pictured).
(4) Feeder cable exits through opening in the well. Shoe plate glued down after final adjustment of central position.
Ready to roll.
I experimented with other US tin plate freight cars. Best combination offers one with screw-mounted trucks and a long coupler neck to avoid contact between coupler and pick-up shoe, i.e. a flat car is the only candidate. Cabooses have also long coupler necks, but the truck held by a retaining ring do not offer enough space for even the thinnest styrene sheet. Gondolas have screw-mounted trucks, but short coupler necks. Box and tank cars have retaining ring-fixed trucks and short coupler necks.
Edited by user 25 October 2016 18:23:03(UTC)  | Reason: Not specified
2 Pages12>
This page was generated in 1.880 seconds.
