Offline Janne75
#1 Posted : 11 August 2015 19:53:51(UTC)
Janne75
I bought some time ago two new 60946 (diesel) mfx sound decoder kits and installed them to my NSB NOHAB's 3137 and 3143. No problems or anything else with 3143, but 3137 has some strange issues.
All sounds and lights work like they should. First I thought it doesn't run at all on digital tracks. I had tried to run it with CS2 on quite low speed settings. I have set speedometer max value to 160 km/h and it did not start to move when speed setting was 60 km/h or so. Only motor sound and rpm raised. On analog track it ran, but it started to run with quite high speed, but was controllable. It was impossible to run it slowly on analog track.
Then some days ago I decided to test it again on digital track and for my surprise I was able to get it running when I set speed setting to around 80 km/h. There is obviously something wrong with this decoder or it's factory settings. I tried to modify some CV settings and speed curve settings etc. I was able to get it better, but not perfect. I would like to run this loco slowly also.
Is there some CV settings I should check or modify to get it running like it should? I had the very same settings than with 3143, but this 3137 runs very differently. No mechanical issues as both locos where basically new analog locos. No gummy gears. Both locos have 60944 5-pole motors and I have installed ball bearings to them.
Any ideas? Confused
Janne
Edited by user 19 August 2015 16:16:05(UTC)  | Reason: Not specified
#2 Posted : 11 August 2015 20:20:22(UTC)
Hi Janne,
I would try swapping the two decoders round, to see if it made a difference. Perhaps there's something in the motor or gears that does not allow slow running on the 3137?
Offline Janne75
#3 Posted : 11 August 2015 21:03:08(UTC)
Janne75
Hi Ray,
That's a good idea. I will swap the decoders and see what happens. If then 3143 still behaves normally there must be something mechanically wrong with 3137. I just rotated both locos motor bogie wheels with fingers and they feel the same and rotate like they should. Gears are new as these locos are basically totally new. I assume something is wrong with decoder or it's settings. It's easy to test, but I will do it in next few days as I'm going to sleep now. I will inform here how it goes when decoders are swapped around.
Janne
#4 Posted : 12 August 2015 07:30:12(UTC)
Hi, Janne,
Even rather new locos can have problems with carbon dust in the gaps of the collector contact areas. It's not just gummed gears that can lead to problems.
Swapping decoders would be my suggestion, too.
Offline Janne75
#5 Posted : 12 August 2015 16:07:07(UTC)
Janne75
I will try swapping the decoders today when I get back to home.
Janne
Offline Janne75
#6 Posted : 12 August 2015 18:52:54(UTC)
Janne75
I just tested the decoders. When I installed 3137 NSB NOHAB's decoder in 3143 NSB NOHAB it started to run like 3137 did before. It started moving at too high speed setting (according to speedo) and it had already faster speed running sounds before it started moving.
So there isn't a mechanical problem in loco and this has something to do with the mfx decoder itself. Maybe it could be improved by modifying some CV values, but I really need help with that.
I swapped the decoders back and 3143 runs as well as before and 3137 got same issues as before. 3137 ran with 3143 decoder very well. First before decoder swapping I thought these problems are caused by not perfect centralised drilling for ball bearing in the motor shield. This could cause some jamming effect also and loco would need more current for moving. But no, it runs perfectly with that other decoder from 3143.
Any ideas what CV values could be modified? RollEyes
Thanks in advance!
Janne
#7 Posted : 12 August 2015 21:52:33(UTC)
Thanks in advance!
Janne
Hi Janne,
It sounds to me like there's something wrong with that decoder. Maybe you should just send it back for a replacement?
Offline 3rail4life
#8 Posted : 13 August 2015 17:05:48(UTC)
3rail4life
Hi Janne,
A reset to factory defaults or a reprogramming may make it behave correctly, otherwise an exchange may be in order...
Gordon
Offline Janne75
#9 Posted : 13 August 2015 17:18:57(UTC)
Janne75
Originally Posted by: 3rail4life Go to Quoted Post
Hi Janne,
Gordon
Hi Gordon, all
I have already tried to reset it back to factory default values. But it didn't help. I got good news today as the seller sends me a new decoder. I asked him to send me only the mfx decoder, but maybe he sends me a completely new 60946 set as he is a big eBay seller. Smile
PS. Does someone know if these 60945/60946/60947 decoder sets are otherwise similar (PCB), but only the decoder itself is programmed differently (= steam, diesel or electric loco sounds)? The reason I ask this is, because I have a complete 60945 set without the correct mSD decoder in my 3084 DB BR 050 steam locomotive. Perhaps I could take this away from it and install that 60946 diesel sound decoder in it and use it with another diesel loco? I have two 3021 DB V200's and one 3081 DB BR 220 with 60944 5-pole motors without decoders at the moment. I could later install a complete 60945 kit to 3084.
Janne
#10 Posted : 13 August 2015 17:44:38(UTC)
Re 60945/6/7: The decoder hardware is the same, they just come with different pre-installed sounds for people who do not have a CS2.
All sold out at the factory, but if you can get a cheap 60946 you can use it for any type of loco.
Offline Janne75
#11 Posted : 19 August 2015 16:13:09(UTC)
Janne75
I got a new 60946 mSD set from the seller. I took only the decoder from this set and installed it in 3137 NSB NOHAB. This time decoder colour was green and not red like the previous decoder. Now it runs like it should.
Then I installed mSD set to 3081 DB BR 220 912-9. I didn't change this time original light bulbs to LED's like I did with both 3137 and 3143. I adjusted some cv values and modified this locos speed curve with CS2. I was able to get it running with very low speed also. So I got it working ok too ThumpUp .
There is one 60946 set coming soon and it will be installed in a new undriven 3021 DB V200 060.
Then there are three more locos waiting for decoder installations. Those have also 60944 5-pole motor kits installed already. Those locos are 3021 with repainted DB V200 045 "ONTRACK GARGO" body, 3021 DB V200 027 and 3050 SBB Ae 6/6 electric loco.
RollEyes
Janne
This page was generated in 0.564 seconds.
